Hi all, cross-post from the Glowy Things forum to see if anyone here has any ideas of how I can troubleshoot.
I've been trying to follow the tutorials for using a Pixie and have not been able to get mine to light up, either using the strandtest or by using an even simpler test file I wrote.
The Pixie is soldered (badly, this is my first rodeo, please be kind) to a Flora, which is also attached to an MSA311 accelerometer (which is working fine thanks to @Dastels). I was worried that I might have shorted the connections to prior to powering up I checked them with a multimeter - no shorts between the power wires and data wire on the Pixie, plus definite connections between the Pixie and the Flora.
Can anyone help with how I should start troubleshooting? Have I missed something obvious or is it likely I've somehow broken the Pixie and it's now dead? (I have 4 others spare to try with if so). Thanks in advance!
Flora and Pixie
- Dalts
Flora and Pixie
- IMG_8226.jpg (60.13 KiB) Viewed 217 times
- IMG_8224.jpg (55.71 KiB) Viewed 217 times
- IMG_8223.jpg (96.72 KiB) Viewed 217 times
- dastels
Re: Flora and Pixie
It appears that you have the data from the Flora attached the the Pixie's Data-out connection (notice the in and out marked between the power & ground pads).
- Dalts
Re: Flora and Pixie
Thanks Dave,
I'd actually done this on purpose as I thought the guide explicitly called it out, but I will turn it round and see what happens. Probably have misinterpreted the instructions :)
- Dalts
Re: Flora and Pixie
Thank you once again Dave.
I don't always try new and complicated electronics projects, but when I do, I completely misunderstand the instructions. Now I have blinded myself several times with 4 Pixies blasting successfully. Also my soldering is getting much neater. :)
- dastels
Re: Flora and Pixie
Sounds good. Yes, those are especially bright.
