adafruit_itertool.islice
tdrew
Post by tdrew »
Hi Guys, I am trying to run the fft_simpletest.py example and having issues with the 'adafruit_itertools.islice' module. It tells me there is no 'islice' module.
# imports """this is line 43, only comments before this line"""
from adafruit_itertools import islice, count
from math import pi, sin, cos, sqrt, pow, log
import array
__version__ = "0.0.0-auto.0"
__repo__ = "https://github.com/tschucker/Teaandtechtime_CircuitPython_FFT.git"
>>> %Run -c $EDITOR_CONTENT
  File "<stdin>", line 2, in <module>
  File "teaandtechtime_fft.py", line 44, in <module>
ImportError: no module named 'adafruit_itertools.islice'
I am running this on the CLUE using the latest Thonny IDE 3.3.13, I have updated the circuitpython version, and the libraries but the error still exists. I am sure it is something simple but I just can't see it. [Sure enough, it is not listed in the module help function.]
>>> help("adafruit_itertools")
object adafruit_itertools is of type str
  encode -- <function>
  find -- <function>
  rfind -- <function>
  index -- <function>
  rindex -- <function>
  join -- <function>
  split -- <function>
  splitlines -- <function>
  rsplit -- <function>
  startswith -- <function>
  endswith -- <function>
  strip -- <function>
  lstrip -- <function>
  rstrip -- <function>
  format -- <function>
  replace -- <function>
  count -- <function>
  partition -- <function>
  rpartition -- <function>
  center -- <function>
  lower -- <function>
  upper -- <function>
  isspace -- <function>
  isalpha -- <function>
  isdigit -- <function>
  isupper -- <function>
  islower -- <function>
Perhaps it has it been relocated or replaced, I would appreciate any assistance
dastels
Re: adafruit_itertool.islice
Post by dastels »
There seems to be something wrong with the adafruit_itertools build/package. I'll let people know. In the meantime grap the source from https://github.com/adafruit/Adafruit_Ci ... ertools.py and drop it into CIRCUITPY/lib. Getting rid of the CIRCUITPY/lib/adafruit_itertools directory is probably a good idea.
tdrew
Post by tdrew »
Thanks heaps Dave, that got me going
dastels
Post by dastels »
Cool. Enjoy it :)
And thanks for the heads up; a fix to what's in the bundle is in progress.
adafruit_support_carter
Where did that fft_simpletest.py example come from? It looks like it's not doing the import correctly:
That's just importing the folder, not the actual module. See correct syntax in example:
https://github.com/adafruit/Adafruit_Ci ... py#L30-L31
Should be something like:
from adafruit_itertools.adafruit_itertools import islice, count
Also see comments here:
https://github.com/adafruit/Adafruit_Ci ... /issues/15
Return to “CLUE Board”
