Hi there,
I'm trying to build the Firewalker sneakers project for.my wife's birthday I'm in $$$ of parts and a day of no making.
One flora board is doa.
The other is impossible to get working.
As I cant seem to find a way of contacting adafruit the company, I'm posting this request for help here.
I've tried the latest arduino ide on 2 pcs and one mac us iij ng many different usb cable and across com ports 3,4,5,6...No go.
The non-doa flora drops com port connection (i see windows device manager refreshing each attempt) on arduino uploads and the ide then times out.
Hard Reset does nothing.
My 60 led neopixel is setup fine with 1000uf cap and 300ohm resistor on data line. 4.3v with enough amps to spare so good on power.
Switch is on.
This should be a very simple project... alas not so much.for me ;(
Going for a walk...
Maybe someone can help me while I go to stretch my legs?
I'd really like to get this to work.
(I ordered another 2 units which will come in on tues)
Thx much
Simon
Cant get Flora to upload properly
- tepalia02
Re: Cant get Flora to upload properly
If despite following everything mentioned here meticulously, https://learn.adafruit.com/getting-star ... s?view=all
it is still not working, I assume you got some bad boards. Hope team adafruit will contact you soon.
- simonlharrison
Hi Tepalia
Thanks, yes I also hope Adafruit is able to provide a solution or replacement!
Yes I did follow the instructions in the link you provided.
Btw and Fyi, I also referenced the Best Practices document on: https://learn.adafruit.com/adafruit-neo ... -practices
Simon
Simon
- Franklin97355
Have you tried to compile a simple program like blink or just a serial like one? Does Arduino see a com port when you plug it in and do nothing and also the computer? Can you post an upload with verbose turned on? Thanks.
- simonlharrison
Hi Franklin,
Thanks for responding. Btw are you an Adafruit engineer? Have you reviewed my prior comments?
In answer to your questions re. board #2: Yes (although the upload process times out). Yes. Yes. Ok.
Some additional info and uploads fyr...
> Windows 10 Pro x64; Arduino IDEO ver 1.8.19
> Flora board #1: Green steady LED; Not populating under com port section in Win10 device manager; Seems to be DOA
> Flora board #2: Green steady LED + Red flashing LED; Connects OK to com port 5 in Win10 device manager; Ardunio sees it OK; Below is the output w/ verbose turning on (you will notice that the upload process hangs after some point, requiring the board be physically disconnected and re-attached from the USB bus); Seems to me that this board is defective (albeit slight less so that board #1) and does not "take" a flashing.
> 2 photos attached
Flora board #2 output
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\simon\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\simon\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\simon\Documents\Arduino\libraries -fqbn=adafruit:avr:flora8 -vid-pid=239A_8004 -ide-version=10819 -build-path C:\Users\simon\AppData\Local\Temp\arduino_build_626824 -warnings=none -build-cache C:\Users\simon\AppData\Local\Temp\arduino_cache_9804 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\simon\Documents\Arduino\sketch_jun08a\sketch_jun08a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\simon\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\simon\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\simon\Documents\Arduino\libraries -fqbn=adafruit:avr:flora8 -vid-pid=239A_8004 -ide-version=10819 -build-path C:\Users\simon\AppData\Local\Temp\arduino_build_626824 -warnings=none -build-cache C:\Users\simon\AppData\Local\Temp\arduino_cache_9804 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\simon\Documents\Arduino\sketch_jun08a\sketch_jun08a.ino
Using board 'flora8' from platform in folder: C:\Users\simon\AppData\Local\Arduino15\packages\adafruit\hardware\avr\1.4.15
Using core 'arduino' from platform in folder: C:\Users\simon\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\sketch\\sketch_jun08a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\sketch\\sketch_jun08a.ino.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\sketch\\sketch_jun08a.ino.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\sketch\\sketch_jun08a.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_pulse.S.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_analog.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\hooks.c" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\hooks.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\WInterrupts.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_pulse.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_digital.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\wiring.c" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_shift.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\HardwareSerial2.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\HardwareSerial1.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\HardwareSerial.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\HardwareSerial3.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\IPAddress.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\PluggableUSB.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\PluggableUSB.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\CDC.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\HardwareSerial0.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\Print.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\Print.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\Stream.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\Tone.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\USBCore.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\WMath.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\WString.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\WString.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\abi.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\abi.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\main.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\main.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10819 -DARDUINO_AVR_FLORA8 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x8004 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Flora\"" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\avr\\1.4.15\\variants\\flora" "C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino\\new.cpp" -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\new.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_pulse.S.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\WInterrupts.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\hooks.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_analog.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_digital.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_pulse.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\wiring_shift.c.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\CDC.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial0.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial1.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial2.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\HardwareSerial3.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\IPAddress.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\PluggableUSB.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\Print.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\Stream.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\Tone.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\USBCore.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\WMath.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\WString.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\abi.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\main.cpp.o"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar" rcs "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\core.a" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\simon\AppData\Local\Temp\arduino_cache_9804\core\core_adafruit_avr_flora8_5d697b9e298dc03a4c4c1539b749d6be.a
Linking everything together...
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824/sketch_jun08a.ino.elf" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824\\sketch\\sketch_jun08a.ino.cpp.o" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824/core\\core.a" "-LC:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824" -lm
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824/sketch_jun08a.ino.elf" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824/sketch_jun08a.ino.eep"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824/sketch_jun08a.ino.elf" "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824/sketch_jun08a.ino.hex"
"C:\\Users\\simon\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\simon\\AppData\\Local\\Temp\\arduino_build_626824/sketch_jun08a.ino.elf"
Sketch uses 3956 bytes (13%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port COM5
PORTS {COM5, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {COM5, } => {COM5, }
Found upload port: COM5
C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\simon\AppData\Local\Temp\arduino_build_626824/sketch_jun08a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\simon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "F"; type = @
Software Version = .w; Hardware Version = �.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
> 2 photos attached
Compiling sketch...
Compiling core...
PORTS {} / {} => {}
Using Port : COM5
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
this check.
- Images(1).zip
- photos of each board
- (804.55 KiB) Downloaded 9 times
- adafruit_support_carter
If you power the board and press reset, the little red LED should pulse. It seems like for at least board #2, that is happening. If that is not happening with board #1, then it does seem like it might not be working.
For board #2 - the COM port showing up and then disappearing could be some kind of third party software interfering. You got that same behavior on both PC's and the Mac?
