ESP32 V2, cant upload from Platform.io
WallyAtTEAGUE
Post by WallyAtTEAGUE »
I have a new Feather ESP32 V2 that powers on and that I can use the serial monitor. I have loaded the VCP drivers successfully.
My project builds (compiles) no problem with the current configuration but fails on upload with the following error:
Connecting....
Chip is ESP32-PICO-V3-02 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: e8:9f:6d:20:2e:94
Uploading stub...
A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)
*** [upload] Error 2
I'm on a Mac, I'm using VSCode with Platform.IO with the following platformio.ini.
[env:adafruit_feather_esp32_v2]
platform = espressif32@^4.4.0
framework = arduino
board = adafruit_feather_esp32_v2
monitor_speed = 115200
upload_port = /dev/cu.usbmodem54790484761
I looked at the Espressif32 v4.4.0 repository on GitHub and the JSON file for the Feather ESP32 V2 is the same as the development branch so it is the most recent. Any ideas what I'm missing? Thanks in advance for any assistance.
mikeysklar
Re: ESP32 V2, cant upload from Platform.io
Post by mikeysklar »
The error code:
There is a closed espressif github issue. Several Mac users were struggling with serial drivers.
https://github.com/espressif/esptool/issues/280
Do you think you have the correct VCP drives installed? This board uses the CP2102N serial converter.
Are you using USB3 or USB2 to upload? Powered hub? Have you tried a lower baudrate?
WallyAtTEAGUE
Thanks so much for the reply. Let me address your questions.
1. I'm using the CH34xVCPDriver linked in the product page. I can successfully use serial monitoring at 115200 so I think the driver works?
2. Upload is direct USB3 using a USBC-C cable directly connected to my MacBook. I also tried using a USB2 port on my monitor (powered USB hub) and got the same error.
3. I changed my upload speed down to 115200 and it didn't help.
upload_speed = 115200
Thanks for the GitHub issue link. I read through it quickly and didn't see anything obvious. I'll give it another read.
adafruit2
Post by adafruit2 »
best bet is to ask platformio - we know it works with arduino IDE for programming, all boards are tested by programming so we were able to program it with esptool!
WallyAtTEAGUE
- SOLVED -
I went back and did some digging in the Platformio forums and also did some testing in the Arduino IDE.
The board presents 2 USB ports and by using the second one I was able to upload successfully. The new Platformio.INI references the "wchusbserial" port which I believe means this is specifically using the CH34x driver package. But I'm not sure about that.
Thank you all for the helpful suggestions!
kikolobo
Post by kikolobo »
Having same issue here with uFL version.
In my case, this issue is only encountered with the uFL version not with the normal V2 version.
I bought about 5 Feathers and all experience the same issue. The ones without uFL do not have issues and program as expected.
In case of the ones with uFL can't even program with Arduino IDE.
Can I exchange them for the normal version ones?
kikolobo
Post by kikolobo »
Found a solution for Mac/platformIO.
Download the latest drivers from WCH-IC:
http://www.wch-ic.com/downloads/CH34XSER_MAC_ZIP.html
