Larger Tip for Large Heat Inserts
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
Post Reply
thetranq
Post by thetranq »
Hello All,
I recently made the Adafruit heat insert rig, and I purchased the "Adjustable 60W Pen-Style Soldering Iron - 120VAC USA Plug - BEST 102C" as the soldering iron. It works great for small heat inserts, but I tend to do larger heat inserts (for instance 1/4"-20 heat inserts) and the included tip is too small to do these very well.
Does anyone know if there are larger-diameter replacement tips for this soldering iron that would work for my application? On most of the tips I see on Adafruit, I cannot find the dimension of the largest part of the cone so I do not know which would be best.
Thanks in advanced
dastels
Re: Larger Tip for Large Heat Inserts
Post by dastels »
I have no idea what 1/4"-20 means but there are tips in the Adafruit shop for M3 and M5 inserts. https://www.adafruit.com/product/4239 and https://www.adafruit.com/product/4249
thetranq
Post by thetranq »
1/4"-20 is a standard SAE thread type. It is a little larger than 5mm
dastels
Post by dastels »
The M5 tip may work fairly well, then.
thetranq
Post by thetranq »
I ordered it and just got it. I can't actually seem to find a way to connect the new tip to the soldering iron?
dastels
Post by dastels »
What iron do you have? Note, on the insert tip page:
All you need is a soldering iron that takes Hakko tips (which nearly all the irons we stock do). I
thetranq
Post by thetranq »
I have the 'BEST" 60W iron.
https://www.adafruit.com/product/3685
dastels
Post by dastels »
Then you're good to go:
Best of all, you can use this iron with Hakko tips.
Unscrew the nut near the base of the heating element, slide the sleeve off and replace the tip by carefully pulling it off the heating element. Reverse the process with the new tip.
thetranq
Post by thetranq »
When I do that, the nut cannot get all the way back to the threads due to the tip getting stuck on the sleeve. I will send a short video shortly
thetranq
Post by thetranq »
https://www.youtube.com/shorts/2CjGHYDd1us
You can see in this video what I mean. The large tip obstructs the sleeve and nut from reaching the threads, it seems that it is not compatible
Post Reply
Return to “Tools Tools Tools”
