Trying to calibrate my FXOS8700 + FXAS21002 IMU with my ardu
Post Reply
ryderj
Post by ryderj »
this is what it is supposed to look like
this is what outputs when I run the sensor calibration read
https://learn.adafruit.com/how-to-fuse- ... s/overview
I have been following this guide to attempt to calibrate each sensor but for some reason, it doesn't work on my nano 33 IoT. It does work on my regular Arduino that has EEPROM. The IoT has no EPROM but it does have flash memory so shouldn't that work the same.
mikeysklar
Re: Trying to calibrate my FXOS8700 + FXAS21002 IMU with my
Post by mikeysklar »
This looks like the error you should expect to see when using an nRF52 board with SPI flash.
It's OK to see Failed to read file / No calibration loaded/found (we haven't made one yet!)
https://learn.adafruit.com/how-to-fuse- ... -3056177-6
Can you paste in the full output from your console?
adafruit2
Post by adafruit2 »
nano33 iot does not have external flash on it - and its untested, so you will not be able to autocalibrate/store the data.
Post Reply
Return to “Arduino”
