ModuleNotFoundError: No module named 'cascadetoml'
Microsoft's MakeCode platform for easy blocks-style programming
Post Reply
PierreDeQuebec
Post by PierreDeQuebec »
In the CircuitPython build process I got the error:
mer jun 29 08:52 $ make BOARD=metro_m4_airlift_lite TRANSLATION=fr
Use make V=1, make V=2 or set BUILD_VERBOSE similarly in your environment to increase build verbosity.
mkdir -p build-metro_m4_airlift_lite/genhdr
GEN build-metro_m4_airlift_lite/genhdr/moduledefs.h
QSTR updated
  File "/home/maison/Documents/Programmation/CircuitPython/7.3.1/circuitpython/ports/atmel-samd/../../tools/gen_nvm_devices.py", line 2, in <module>
    import cascadetoml
make: *** [../../supervisor/supervisor.mk:75 : build-metro_m4_airlift_lite/genhdr/devices.h] Erreur 1
But cascadetoml module is not present as required by import command in circuitpython/tools/gen_nvm_devices.py file.
Should I manually install the module in question?
I specify that I downloaded version 7.3.1 with the following command:
git clone --depth 1 --branch 7.3.1 https://github.com/adafruit/circuitpython.git
Regards,
Pierre
dastels
Re: ModuleNotFoundError: No module named 'cascadetoml'
Post by dastels »
Yes. have a look at requirements-dev.txt for a list of what you need.
PierreDeQuebec
Thank you dastels.
PierreDeQuebec
I finally managed to install cascadtoml but not without difficulty! My problem was: my system didn't accept pip command but rather pip3. Weird. Digging around, pip was installed and needed /usr/bin/python but 'python' didn't exist. But python3 existed and pointed to python3.10.4. The solution was to create a symbolic link named python and pointing to python3 and everything was back to normal.
cd /usr/bin
sudo ln -s python3 python
Post Reply
Return to “MakeCode”
