adafruit metro board
dirtyoledog
Post by dirtyoledog »
I have a board I was asked to attempt to program. I was given the code, believe I have set all arduino options properly, but always get a fault. there is a lcd screen attached which simply just lights up and does nothing..here is the error..
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x90
avrdude: verification error, first mismatch at byte 0x0000
0x00 != 0x0c
avrdude: verification error; content mismatch
here is the program I was asked to send to the board. It is my understanding that these items were at one time working
#include <LiquidCrystal.h>
#include <SPI.h>
#include <RH_RF69.h>
//This is code for Arduinos. You need Adafruit's RadioHead library to compile this.
//ard1 is the receiving side, ard2 is the transmiting side (with a button)
//*Only* ard2 can transmit
//Used to change messages + logic
#define transmit
//Used to control what pins we use
#define ard2
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
#ifdef ard1
const int rs = 5, en = 6, d4 = 7, d5 = 8, d6 = 9, d7 = 10;
#endif
#ifdef ard2
const int rs = 5, en = 6, d4 = 7, d5 = 8, d6 = 9, d7 = 4;
#endif
#ifdef receive
const char* text[] = {
  //Each must be max. 16 characters in length, per row
  "** THIS IS A  **",
  "**  GEOCACHE  **",
  "*** GC798H9  ***",
  "*** by BWJM  ***",
  "**  WIRELESS  **",
  "**  AMMO CANS **",
  "To unlock the   ",
  "next stage,     ",
  "send a member of",
  "your team to    ",
  "the transmitter ",
  "to push button. ",
  "Only when the   ",
  "button has been ",
  "released will   ",
  "the solution    ",
  "be revealed.    ",
  "The transmitter ",
  "can be found at "
const char* rText[] = {
  //we don't need to space-pad here, (except for #1, because of something prior) because the strings always get bigger
  "The button      ",
  "was pushed.     ",
  "The solution",
  "will be shown",
  "for 7 seconds.",
  "Are you ready??",
#endif
#ifdef transmit
  "In order to     ",
  "unlock the final",
  "stage of this   ",
  "geocache,       ",
  "push the button ",
  "to transmit     ",
  "The coordinates ",
  "will be shown   ",
  "at the first    ",
  "stage.          "
#endif
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#define RF69_FREQ 868.0
#ifdef ard1
  #define RFM69_CS      4
  #define RFM69_INT     3//??? I think?
  #define RFM69_RST     2
#endif
#ifdef ard2
  #define RFM69_CS      10
  #define RFM69_INT     2 //??? I think?
  #define RFM69_RST     3
#endif
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
int16_t packetnum = 0;
int loopStartMs;
int section = 0;
byte degree[8] = {
  B01110,
  B01010,
  B01110,
  B00000,
  B00000,
  B00000,
  B00000,
#define RETRY_GAP 100
#define MAX_RETRYS 35
int lastRetry = -RETRY_GAP;
bool tryingToSend = false;
int retrys = 0;
  lcd.begin(16, 2);
  #ifdef receive
  lcd.print("** THIS IS A   *");
  lcd.print("**  GEOCACHE   *");
  #endif
  #ifdef transmit
  lcd.print("In order to    *");
  lcd.print("unlock the final");
  #endif
  lcd.createChar(0, degree);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
  if (!rf69.init()) {
    lcd.setCursor(0,0);
    lcd.print("Sorry, there was");
    lcd.setCursor(0,1);
    lcd.print("an error. (#1)  ");
    delay(200000);
    while (1);
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
    lcd.setCursor(0,0);
    lcd.print("Error received, ");
    lcd.setCursor(0,1);
    lcd.print("but continuing. ");
    delay(3000);
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
  rf69.setTxPower(20, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  rf69.setEncryptionKey(key);
  lcd.setCursor(0,0);
  int i;
  for (i = 0; i <
  #ifdef receive
  10
  #endif
  #ifdef transmit
  5
  #endif
  ; i = i + 1) {
    lcd.print(text[(2 * i)]);
    lcd.setCursor(0,1);
    lcd.print(text[(2 * i) + 1]);
    lcd.setCursor(0,0);
    delay(4000);
  #ifdef receive
  lcd.print("N 43");
  lcd.write(byte(0));
  lcd.print(" 16.693'   ");
  lcd.setCursor(0,1);
  lcd.print("W 80");
  lcd.write(byte(0));
  lcd.print(" 22.823'   ");
  delay(6000);
  lcd.setCursor(0,0);
  lcd.print("Waiting for     ");
  lcd.setCursor(0,1);
  lcd.print("button push...  ");
  #endif
  #ifdef transmit
  lcd.print("Push button.    ");
  lcd.setCursor(0,1);
  lcd.print("Press firmly.   ");
  #endif
  loopStartMs = millis();
void sendButtonPressed() {
  retrys = 0;
  tryingToSend = true;
#ifdef transmit
  bool waitingForRelease = false;
  bool buttonReleased = false;
#endif
  //Perhaps 12 is for when data comes in?
  //lcd.setCursor(0,0);
  //lcd.print(digitalRead(12));
  #ifdef transmit
  if (tryingToSend) {
    if (rf69.available()) {
      uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
      uint8_t len = sizeof(buf);
      rf69.recv(buf, &len);
      retrys = 0;
      lcd.setCursor(0,0);
      lcd.print("Coordinates are ");
      lcd.setCursor(0,1);
      lcd.print("shown at stage 1");
      delay(20000);
    } else if (retrys > MAX_RETRYS) {
      //only do something if we've given enough time for a ack
      if (millis() > (lastRetry + RETRY_GAP)) {
        lcd.setCursor(0,0);
        //lcd.print("Sorry, there was");
        //lcd.setCursor(0,1);
        //lcd.print("an error. (#2)  ");
        lcd.setCursor(0,1);
        lcd.print("Press firmly... ");
        retrys = 0;
        //while (1);
    } else if (millis() > (lastRetry + RETRY_GAP)) {
      char radiopacket[2] = "a";
      itoa(packetnum++, radiopacket+13, 10);
      // Send a message!
      rf69.send( (uint8_t *) radiopacket, strlen(radiopacket));
      rf69.waitPacketSent();
      retrys++;
      delay(RETRY_GAP);
  #endif
  #ifdef receive
    //send a message to ack
    // Send a message!
    buttonPressed();
   int curSection = ((millis() - loopStartMs) / 4000) % 5;
   //if ((millis() % 1000) > 50) {
   //  lcd.print((millis() - loopStartMs) * 4000);
   if ((curSection == 0) || (curSection == 1)) {
    curSection = 0;
   } else if (curSection == 2) {
    curSection = 1;
   } else {
    curSection = 2;
   if (curSection != section) {
    section = curSection;
    if (section == 0) {
      lcd.setCursor(0,0);
      lcd.setCursor(0,1);
    } else if (section == 1) {
      lcd.setCursor(0,0);
      lcd.print("The transmitter ");
      lcd.setCursor(0,1);
      lcd.print("can be found at ");
    } else {
      lcd.setCursor(0,0);
      lcd.print("N 43");
      lcd.write(byte(0));
      lcd.setCursor(0,1);
      lcd.print("W 80");
      lcd.write(byte(0));
  #endif
  #ifdef transmit
    int buttonValue = analogRead(0);
    lcd.setCursor(0,0);
    //lcd.print(buttonValue);
    if ((buttonValue < 999) && !waitingForRelease && !buttonReleased) {
      //don't update display if we don't need to
      lcd.setCursor(0,0);
      lcd.print("                ");
      lcd.setCursor(0,1);
      lcd.print("Release button. ");
      waitingForRelease = true;
    } else if ((buttonValue > 1005) && waitingForRelease && !buttonReleased) {
      lcd.setCursor(0,1);
      lcd.print("Transmitting... ");
      sendButtonPressed();
      //delay(4000);
  #endif
#ifdef receive
void buttonPressed() {
  int j;
  lcd.setCursor(0,0);
  for (j = 0; j < 3; j = j + 1) {
    lcd.print(rText[(2 * j)]);
    lcd.setCursor(0,1);
    lcd.print(rText[(2 * j) + 1]);
    lcd.setCursor(0,0);
    delay(4000);
  lcd.print("N 43");
  lcd.write(byte(0));
  lcd.print(" 16.638'  ");
  lcd.setCursor(0,1);
  lcd.print("W 80");
  lcd.write(byte(0));
  lcd.print(" 22.734'  ");
  delay(7000);
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  section = 0;
#endif
Reason: Add code tag
dastels
Re: adafruit metro board
Post by dastels »
Do you have the board set correctly? I.e. it reflects exactly the board you have attached? And what is the board?
dirtyoledog
i have the software set to arduino uno. avrisp mkII is the programmer setting. more than this i am not sure what to check. the board is an adafruit metro.
dastels
Post by dastels »
OK, which Metro?
dirtyoledog
metro board
metro board
hopefully the image is displayed
adafruit metro gc-2 94v-0
e336755
2915
those are the details I have,
so Dave, do you know what the error message represents and since you are asking about the board, is their a difference based on the different boards?
if you know the solution for one board can you share it, ?
dastels
Post by dastels »
It would seem to be a Metro 328. Yes, boards are all different and you must set the Tools->Board selection to match the board you have. I see there is an "Adafruit Metro" board in the "Adafruit Boards" submenu of Tools->Board. I suspect that will work.
Can you past all the build output?
dirtyoledog
there is a adafruit circuit playground under tools boards, nothing else
dirtyoledog
what is the problem based on the error code. adafruit states, set board to arduino uno. i have already sent the output previously. what does the error code mean. and what do i do to fix it
dastels
Post by dastels »
Yes, UNO should work since it's just a copy of the UNO. Please post all of the build output for more context.
dirtyoledog
i sent this code to another arduino uno..no issue, then sent it to the original one using a new usb cable..it compiled and upload but the lcd is just glowing, and or shows gibberish....and still no definition of the error
dirtyoledog
no more time tonight
Return to “Metro, Metro Express, and Grand Central Boards”
