Hello all,
some weeks ago I bought two ItsyBitsy M0 Express from a German dealer. They both show the same problem. They came with an old version of CircuitPython (I don't remember) and Bootloader 3.7.0. After updating CircuitPython to 7.3.1 the CIRCUITPY drive didn't show up as CIRCUITPY but as 4921-8571.
Anyway, I started developing my code and after a while I realized that the filesystem was corrupted. Then I did a filesystem erase via the REPL console and the drive name changed to CIRCUITPY :-)
After some further programming work the board suddenly went into Safe mode and told me that it crashed into the Hardfault_Handler.
A second filesystem erase brings no change. The second board shows the same effects.
Now I don't know if this is a hardware problem specific to a certain lot or a problem of CircuitPython 7.3.1. Attached is a picture of the bag of one of the boards so you can see the lot No.
For the moment I continue my development on a Feather M0 Express with CircuitPython 7.3.0 that seems to work
Can anyone give me further info about what the problem is and how to solve it? Any help is very much appreciated.
Elektrix
ItsyBitsy M0 filesystem problem?
- Elektrix
- ItsyBitsy.jpg (64.37 KiB) Viewed 282 times
- dastels
Re: ItsyBitsy M0 filesystem problem?
Did you update the bootloader to 3.14.0?
- Elektrix
No I didn't. I would do so if you'd advise me to.
Elektrix
Elektrix
- dastels
It's old enough that I would try it. See the instructions/link at the bottom right of https://circuitpython.org/board/itsybitsy_m0_express/.
- Elektrix
After updating the bootloader to 3.14.0 the board stays in boot mode (drive ITSYBOOT is visible) and returns in this mode after reset. When I upload CircuitPython 7.3.1 (filename adafruit-circuitpython-itsybitsy_m0_express-de_DE-7.3.1.uf2) the CIRCUITPY drive appears again and the old files in this drive are still visible. BUT: the board goes to Safe mode again with tha Hardfault_Handler. Then I reduced the code.py file to one single line: print("Hello") and it worked. Then I added a second line: import time and got Errno 5. After deleting this second line again I got Errno 5 again. It also looks like renaming a file sometimes crashes the file (file length 0 afterwords) but this is not reproducible. To me this looks like the filesystem or the whole system is not in a stable state.
Elektrix
Elektrix
- dastels
It sounds like you've consulted https://learn.adafruit.com/welcome-to-c ... es-2978456 already.
- Elektrix
Yes that's true. But it looks like the filesystem is still corrupted after reloading CircuitPython. I have no idea how to fix this. For the moment I continue on my Feather M0 Express with CP 7.3.0 which is working stable but in the end I would like to use the ItsyBitsy.
Elektrix
Elektrix
- dastels
I asked internally to see if anyone has seen this sort of thing.
- adafruit2
did you run the storage erase command ?
https://learn.adafruit.com/welcome-to-c ... em-2987288
you probably need to do that
- Elektrix
Now I am able to reproduce the error. On my ItsyBitsy M0 Express I have the bootloader 3.14.0 and CircuitPython 7.3.1 on 2022-06-22 (German language version).
From the REPL I do:
From the adafruit CircuitPython bundle (extracted from adafruit-circuitpython-bundle-7.x-mpy-20220708.zip) I copy the libraries adafruit_bus_device and adafruit_mcp230xx into the lib folder.
I copy two files onto the ItsyBitsy.
The file with the name code.py goes into the main folder:
The file with the name test.py goes into the lib folder:
Until here everything is ok. Now I uncomment the last line of test.py and the system crashes with a Hardfault Handler error.
After that you can start again with import storage and storage.erase_filesytem() and have the same behaviour again.
This is the same when a MCP23017 is connected or not. I did it before with the CircuitPython bundle release 20220704 with the same result.
I absolutely have no idea what is going on there. Any help is very much appreciated!
Elektrix
From the REPL I do:
import storage
storage.erase_filesystem()
import test
import time
import board
import digitalio
from audiocore import RawSample
# from adafruit_mcp230xx.mcp23017 import MCP23017
Elektrix
- adafruit2
ok i think thats actually unrelated to filesystem. it might actually be you running out of memory in a wierd way (it shouldnt hardfault tho)
first up, try "absolute latest" circuitpy 8.x - and paste the REPL outptu here :)
- Elektrix
I downloaded CircuitPython 8.0.0-alpha.1 for ItsyBitsy M0 Express German version and installed it. Then I did erase_filesystem() via REPL. Then I uploadad the same libraries as before but in the 8.x version from adafruit-circuitpython-bundle-8.x-mpy-20220708.zip and my two files as described before. Same result :-(
Elektrix
Elektrix
- adafruit2
ok can ya open up a github issue on https://github.com/adafruit/circuitpython
with the exact files/REPL output?
- Elektrix
