FX Sound Board
- JMinshew
FX Sound Board
Hello! I purchased both the FX Sound Board 3.5mm out and amplifier versions. I've tried hooking each up to three separate computers now and neither is recognized by any computer so I can upload the sound files to the board. Any advice? Running different versions of windows on each. Power light glows green when plugged into the computer using USB connection. Thoughts?
- adafruit_support_carter
Re: FX Sound Board
Double check the USB cable being used. Use the USB cable with some other device and make sure it can move data and is not a charge only USB cable.
