Feather RP2040 - OLED SH1107 Display Doesn't Show
mechtech5473
Post by mechtech5473 »
I've wired my OLED to my Feather and I see it when I use the I2C Scan example but when i use the sample code it doesn't work. Tried adjusting for the second port by switching &Wire to &Wire1 When creating the display object. I checked my power 3.3V power is good and checked board for 12v connection in case my ground had issues and it looks good. Checked resistance to pins from OLED to Micro Controller looks good. I don't know where i'm going wrong.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#include <Adafruit_TestBed.h>
extern Adafruit_TestBed TB;
#define SECONDARY_I2C_PORT &Wire1
Adafruit_SH1107 display = Adafruit_SH1107(64, 128, &Wire1);
#define NeoPixel_Pin 16
#define NeoPixel_Count 1
Adafruit_NeoPixel strip(NeoPixel_Count, NeoPixel_Pin, NEO_GRB + NEO_KHZ800);
#define Button_A 9
#define Button_B 8
#define Button_C 7
  // put your setup code here, to run once:
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  delay(100);
  strip.begin();
  strip.show();
  delay(50);
  strip.setPixelColor(0,100,100,100);
  delay(100);
  strip.setPixelColor(0,100,0,0);
  strip.show();
  Serial.begin(115200);
  //while (!Serial) delay(10);
  delay(250);
  strip.setPixelColor(0,100,20,0);
  strip.show();
  delay(500);
  Serial.println("System Starting");
  //Port Test
  Serial.print("Secondary Port (Wire1) ");
  TB.theWire = SECONDARY_I2C_PORT;
  TB.printI2CBusScan();
  strip.setPixelColor(0,100,40,0);
  strip.show();
  Serial.println("Start Display");
  display.begin(0x3C, true); // Address 0x3C default
  display.display();
  strip.setPixelColor(0,100,60,0);
  strip.show();
  delay(1000);
  display.clearDisplay();
  display.print("Started Display");
  display.display();
  delay(1000);
  Serial.println("Setup Buttons");
  strip.setPixelColor(0,100,80,0);
  strip.show();
  pinMode(Button_A, INPUT_PULLUP);
  pinMode(Button_B, INPUT_PULLUP);
  pinMode(Button_C, INPUT_PULLUP);
  // put your main code here, to run repeatedly:
  strip.setPixelColor(0,0,0,100);
  strip.show();
  if(!digitalRead(Button_A)) Serial.print("A");
  if(!digitalRead(Button_B)) Serial.print("B");
  if(!digitalRead(Button_C)) Serial.print("C");
  delay(500);
adafruit_support_carter
Re: Feather RP2040 - OLED SH1107 Display Doesn't Show
Try removing the residual testbed code. Run the example:
https://learn.adafruit.com/adafruit-128 ... de-3071194
and change only the one line to reference Wire1:
mechtech5473
Gave it try and same problem not displaying.
#include <SPI.h>
#include <Wire.h>
// OLED FeatherWing buttons map to different pins depending on board:
#if defined(ESP8266)
  #define BUTTON_A  0
  #define BUTTON_B 16
  #define BUTTON_C  2
#elif defined(ESP32) && !defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2)
  #define BUTTON_A 15
  #define BUTTON_B 32
  #define BUTTON_C 14
#elif defined(ARDUINO_STM32_FEATHER)
  #define BUTTON_A PA15
  #define BUTTON_B PC7
  #define BUTTON_C PC5
#elif defined(TEENSYDUINO)
  #define BUTTON_A  4
  #define BUTTON_B  3
  #define BUTTON_C  8
#elif defined(ARDUINO_NRF52832_FEATHER)
  #define BUTTON_A 31
  #define BUTTON_B 30
  #define BUTTON_C 27
#else // 32u4, M0, M4, nrf52840, esp32-s2 and 328p
  #define BUTTON_A  9
  #define BUTTON_B  6
  #define BUTTON_C  5
#endif
  Serial.println("128x64 OLED FeatherWing test");
  delay(250); // wait for the OLED to power up
  Serial.println("OLED begun");
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  display.display();
  delay(1000);
  // Clear the buffer.
  display.display();
  display.setRotation(1);
  Serial.println("Button test");
  pinMode(BUTTON_A, INPUT_PULLUP);
  pinMode(BUTTON_B, INPUT_PULLUP);
  pinMode(BUTTON_C, INPUT_PULLUP);
  // text display tests
  display.setTextSize(1);
  display.setTextColor(SH110X_WHITE);
  display.setCursor(0,0);
  display.print("Connecting to SSID\n'adafruit':");
  display.print("connected!");
  display.println("IP: 10.0.1.23");
  display.println("Sending val #0");
  display.display(); // actually display all of the above
  if(!digitalRead(BUTTON_A)) display.print("A");
  if(!digitalRead(BUTTON_B)) display.print("B");
  if(!digitalRead(BUTTON_C)) display.print("C");
  delay(10);
  yield();
  display.display();
kb4mg
Post by kb4mg »
Did you ever figure this out? Mine works intermittently. I am using the Teesy3.1 platform and I2C interface. I have actually got it to work a few times, but if I unplug it and plug it in again, the display may not initialize. Very confused. I am toggling the RST pin using one of my GPIO pins, which I think is necessary.
kb4mg
Post by kb4mg »
For whatever reason, the OLED does always get started by the display.begin() class method. I suspect it is a timing issue. These OLED displays were likely surplus from some Chinese products that may have had some different timing from the Arduino boards.
I did some experimenting and saw that if I reset the processor board about 5 times (sometimes more), the display starts working.
To initialize the display I did the following in my code:
for(int i =1; i<8; i++) {
delay(250);
display.display();
delay(2000);
See if this help with your case as well. I would love to know.
@MechTech54 Try touching up the soldering. It's most likely a connection issue.
mechtech5473
I got a new Board and it worked with no issues. The board was either damaged during storage (was 8 months before i used it) or bad soldering although.
kb4mg
Post by kb4mg »
Thanks guys! I looked at the board carefully. Hard to tell if there are any issues. I am not using the headers, just the STEMMA QT connector for I2C and the Teensy 3.1 MCU board. Strange problem.
@kb4mg Please start a new thread for your issue.
Return to “Other Arduino products from Adafruit”
