Hello all!
I am trying to make a complex object and I need to control multiple solenoids (at least 32) using Raspberry Pi and custom python code. I am designing now the hardware connections and I think two of the Adafruit 16-Channel PWM / Servo Bonnet for Raspberry Pi (https://www.adafruit.com/product/3416) is what I am looking for? Somehow I can access read and write in in the Raspberyr Pi for this module and then I have 32 channels that I can arbitrarily control. I would like to ask if this is the right path, and if so, what Solenoids do you recommend for this board? I want to be able to push the equivalent to finger press on old keyboards. I'm not sure if I need anything else?
Raspbery Pi 4 model B -> 2 Adafruit 16-Channel PWM / Servo Bonnet and 32 x solenoids.
Thanks in advance.
Setting up PWM / Servo Bonnet for solenoids
- adafruit_support_carter
Re: Setting up PWM / Servo Bonnet for solenoids
You'll want something else for driving solenoids.
Checkout these projects:
https://learn.adafruit.com/robotic-xylo ... uit-python
https://learn.adafruit.com/wireless-ble ... e/overview
for some examples.
for some examples.
- kashik
Ok so, let's focus a bit on that answer.
Using the Arduino example. Doing this (https://learn.adafruit.com/robotic-xylo ... id-circuit) four times is a good option? I may need to connect all of the arduinos together in the single codebase, that doesn't seem a great option but want to hear what do you think?
Regarding the wireless example, (also I don't really need that bluetooth) it seems a fairly elegant implementation. I'm ok with MIDI, just need a replacement for the bluetooth, and would pretty much like to get this in normal python.
What do you recommend?
You could use the PWM/Servo board - or one of our GPIO expander boards to get enough channels. But you would still need a MOSFET and diode on each output pin in order to drive the solenoids.
A Grand Central board would also give you enough pins. But you still would need the MOSFET/diode driver, since a GPIO pin will not drive a solenoid.
https://www.adafruit.com/product/4064
- kashik
Ok so that is great.
I think I got my system here without bluetooth keeping the same materials as in https://learn.adafruit.com/wireless-ble ... e/overview.
Now the MOSFET and diode driver can I buy from this store too? Kind of trying to make a basket that matches
MOSFETs here: https://www.adafruit.com/product/355
Your diodes should be rated for at least as much current as your Solenoids will draw.
We have diodes here rated for up to 1A : https://www.adafruit.com/product/755
