Your pixels are your biggest load. So you want to wire power from your battery pack directly to the pixels - not through the processor. 22AWG wire has a resistance of about 0.016 ohms per foot or .056 ohms for your 3.5 foot run. Even at a 10A current draw, that is only a 0.56v drop. (Actually less because you also have the power and ground traces on the strip connected in parallel).
So you would have a 3.5 foot run of power and ground, then tap off for a connection to the first pixel, the mid pixel and the last pixel. If you have enough room, you could do 3 separate runs instead for even lower resistance.
Then run power and ground from the first pixel back to your processor.
Power plan with neopixel advice
- Draculen
Re: Power plan with neopixel advice
Ah okay this makes perfect sense now.
Bill your knowledge Is vast and amazing! Thank you the valuable Information!!!!
