I have a working setup, and everything works fine.
I have one question though:
With Circuitpython, is it possible to access / use RGB colors - > eg: (155, 10, 122) for a pixel?
I want to be able to set all pixels to certain RGB colors in a loop, instead of the simple integer -> palette in all Adafruit examples.
Is that possible? Or only available when work with C / C ++ and other libraries like fastLED etc?
Thanks in advance,
Marcelo
Matrix M4 + 64 + 32 Matrix
- handful
Re: Matrix M4 + 64 + 32 Matrix
Have a simpler way of asking the question:
Is there an equivalent to matrix.drawPixel(x,y,0,0,0) in Python?
Thanks Folks!
M
Thanks Folks!
M
- adafruit_support_carter
In general, no. You'll need to setup the colors in a palette and then use the palette indices to set the pixel colors:
https://learn.adafruit.com/circuitpytho ... raw-pixels
- handful
Ok Thanks!
I will jump to other libraries then, I don't think it will be wise to do a massive array for that :)
Best
Marcelo
Best
Marcelo
