Serial1.print("T05.wav");
#include "Adafruit_Soundboard.h"
#define PIXEL_PIN 5 // Pin connected to neo pixels
#define FIREPIN 7 // Fire button
#define PIXEL_COUNT 30 // Count of neo pixels
#define SWITCHPIN1 15 // Analog
#define SWITCHPIN2 16 // Analog
#define SWITCHPIN3 17 // Analog
#define SWITCHPIN4 18 // Analog
#define SFX_TX 1
#define SFX_RX 0
#define SFX_RST 3
Adafruit_Soundboard sfx = Adafruit_Soundboard(&Serial1, NULL, 3);
int buttonState = 0;
int modeState1 = 0;
int modeState2 = 0;
int modeState3 = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
Serial1.begin(9600);
// if (!sfx.reset()) {
// Serial.println("Not found");
// while (1);
// Serial.println("SFX board found");
strip.begin();
strip.show();
pinMode(FIREPIN, INPUT_PULLUP);
pinMode(SWITCHPIN1, INPUT_PULLUP);
pinMode(SWITCHPIN2, INPUT_PULLUP);
pinMode(SWITCHPIN3, INPUT_PULLUP);
pinMode(SWITCHPIN4, INPUT_PULLUP);
uint8_t i;
//Button Check
buttonState = digitalRead(FIREPIN);
//////////////////MODE1//////////////////////
if (buttonState == HIGH)
// Nice flash and fade out over about 3/4 of a second:
animate_gradient_fill(strip,
255, 255, 255,
255, 0, 0,
150);
// Then flash from purple to nothing over a longer period.
255, 0, 0,
20, 0, 0,
150);
20, 0, 0,
0, 0, 0,
150);
else {
strip.setPixelColor(i, 0,0,0); //Button not pressed, turn off pixels
strip.show(); //Show no pixels
//////////////////MODE2//////////////////////
//////////////////MODE3//////////////////////
// Linear interpolation of y value given min/max x, min/max y, and x position.
float lerp(float x, float x0, float x1, float y0, float y1)
// Clamp x within x0 and x1 bounds.
x = x > x1 ? x1 : x;
x = x < x0 ? x0 : x;
// Calculate linear interpolation of y value.
return y0 + (y1-y0)*((x-x0)/(x1-x0));
// Get the color of a pixel within a smooth gradient of two colors.
uint32_t color_gradient(uint8_t start_r, // Starting R,G,B color
uint8_t start_g,
uint8_t start_b,
uint8_t end_r, // Ending R,G,B color
uint8_t end_g,
uint8_t end_b,
float pos) // Position along gradient, should be a value 0 to 1.0
// Interpolate R,G,B values and return them as a color.
uint8_t red = (uint8_t) lerp(pos, 0.0, 1.0, start_r, end_r);
uint8_t green = (uint8_t) lerp(pos, 0.0, 1.0, start_g, end_g);
uint8_t blue = (uint8_t) lerp(pos, 0.0, 1.0, start_b, end_b);
return Adafruit_NeoPixel::Color(red, green, blue);
// Set all pixels to the specified color.
void fill_pixels(Adafruit_NeoPixel& pixels, uint32_t color)
for (int i=0; i < pixels.numPixels(); ++i) {
pixels.setPixelColor(i, color);
strip.show();
void animate_gradient_fill(Adafruit_NeoPixel& pixels, // NeoPixel strip/loop/etc.
uint8_t start_g,
uint8_t start_b,
uint8_t end_g,
uint8_t end_b,
int duration_ms) // Total duration of animation, in milliseconds
unsigned long start = millis();
// Display start color.
fill_pixels(pixels, Adafruit_NeoPixel::Color(start_r, start_g, start_b));
// Main animation loop.
unsigned long delta = millis() - start;
while (delta < duration_ms) {
// Calculate how far along we are in the duration as a position 0...1.0
float pos = (float)delta / (float)duration_ms;
// Get the gradient color and fill all the pixels with it.
uint32_t color = color_gradient(start_r, start_g, start_b, end_r, end_g, end_b, pos);
fill_pixels(pixels, color);
// Update delta and repeat.
// Display end color.
fill_pixels(pixels, Adafruit_NeoPixel::Color(end_r, end_g, end_b));
