TFT 1947 I2C Touchscreen (Capactive)
I have one of these TFTs. It works fine when mounted on a UNO.
When it lead it out (4-in. 'jumpers') the display still works but the touchscreen does not.
I have swapped and changed out 'jumpers' to no avail.
I have 9, 10, 11, 12, 13, A4, A5, 5V, and 2 GNDs connected.
Again, when wired in this off-the-board manner, the display works but the touchscreen does not.
Is the I2C touchy?
I've had the oscilloscope on it. I see what I presume to be the INIT poll from the UNO (SCL SDA), but that is all.
Touching the screen doesn't result any activity on the I2C lines.
Using the Adafruit GFX and FT6206 library.
- dastels
Re: TFT 1947 I2C Touchscreen
Try connecting to the SDA/SCL pins, not A4/A5. By default A4/A5 are not connected to SDA/SCL.
- dx160
Thanks for your Reply.
When I do that, the display dims (a lot) with SDA connected.
It works as a module plugged into the UNO.
Running out some wires should be simple enough, but this is where it craters.
I'm using 11, 12, 13 (as opposed to the ICSP).
I have tried with A4/A5 to A4/A5, A4/A5 to SDA/SCL, SCL/SDA to A4/A5, and SDA/SCL to SDA/SCL.
No combination works (it either dims or doesn't boot (white raster)).
I do not understand.
What more do I need than 9-13 (Uno) to 9-13 (TFT), 5V & GND (Uno) to 5V &GND (TFT)?
I need the I2C, too and that's the bugger here.
Is there a diagram that clearly indicates the wiring between the two and which pads to cut or blob?
I have even tried with every UNO pin connected to every TFT pin - and it just does not happen.
- 1947_cuts_blobs.jpg (877.29 KiB) Viewed 315 times
- dastels
I2C with the shield should work with SDA<->SDA and SCL<->SCL.
Why do you need it not mounted to the UNO?
- dx160
Needs to be Remote for my purpose/s.
OK, here it is (The Solution) --
It needs connectivity from SDA/SCL on the long header (the pins north of 13) and RESET.
A) If I have UNO A4, A5, SDA, SCL, 9-13 jumpered over to the TFT points it tanks.
B) With 'SDA', 'SCL', 9 - 13, and Reset going to their corresponding TFT points -- All's Well.
C) There's A4, A5, 'SDA', 'SCL' connectivity with the TFT parked on the UNO, but no "conflict", that doesn't scupper the deal. [Note A]
Don't ask me why.
Don't ask me why.
- IMG_20220801_091058114.jpg (92.08 KiB) Viewed 312 times
- dastels
Good that you got it going!
- dx160
Any known issues using the FT6206 library with ESP32?
With SDA/SCL disconnected, the display part of my sketch runs the way I intend.
With SDA/SCL connected it's just a white raster.
Touching inside my "defined area" is supposed to Erase the display (all black), which it attempts to do.
I'm not using the Adafruit GFX because I couldn't figure out how to implement that (specifically via 'VSPI').
I don't see that as the issue, but anyway.
I have 5V/3V level shifters between the ESP32 and the 1947.
#include <Wire.h> // SCL, 22; SDA, 21
#include <Arduino_GFX_Library.h> // includes in this order
#include "MAX31855.h" // or disply will not work
#include <Adafruit_FT6206.h>
// The FT6206 uses hardware I2C (SCL/SDA)
Adafruit_FT6206 Touch = Adafruit_FT6206(); // Touch. associated with TouchSensor pad
// Using VSPI for TFT
#define TFT_SCK 18
#define TFT_MOSI 23
#define TFT_MISO 19 // optional (there is no data out of tftDisp)
#define TFT_CS 32
#define TFT_DC 33
#define TFT_RESET 17 // optional, P-UP
#define tcCS1 25 // tcbd1 CS
#define tcCS2 26 // tcbd2 CS
Arduino_ESP32SPI bus = Arduino_ESP32SPI(TFT_DC, TFT_CS, TFT_SCK, TFT_MOSI, TFT_MISO);
Arduino_ILI9341 tftDisp = Arduino_ILI9341(&bus, TFT_RESET);
MAX31855 tcbd1;
MAX31855 tcbd2;
float tRemote_1;
float tRemote_2;
bool RecordOn;
bool yelStat = false;
int xx;
int yy;
int Xpoint = 5;
float cdeg[2];
int cC[2]; // float cdeg[], X 100, and remaining DECimal trunc'd
int lowLimit = 1800; // This could be a User setting, Y-axis, map()
int highLimit = 3800; // This could be a User setting, Y-axis, map()
const unsigned long Lockout = 750;
unsigned long debounceMark;
bool yelActive = false;
void setup()
Serial.begin(19200);
tftDisp.begin();
delay(3000);
Serial.println("wait for it");
if (!Touch.begin(40)) // # is sensitivity threshold (40)
Serial.println("Touchscreen NAK !");
//while(1);
else
Serial.println("\r\n\r\nTouchscreen started.");
tftDisp.fillScreen(BLACK);
// origin = left,top landscape (USB left upper)
tftDisp.setRotation(1);
//greenBtn();
yelBox(); // defined area, touch-zone
Serial.print("RecOn ");
Serial.println(RecordOn);
// HSPI for thermocouple boards
tcbd1.selectHSPI();
tcbd1.begin(tcCS1);
tcbd1.setSPIspeed(500000);
tcbd2.selectHSPI();
tcbd2.begin(tcCS2);
tcbd2.setSPIspeed(500000);
delay(3000);
Yscale();
- dastels
What level shifters are you using?
- dx160
The MOSFET type, the bidirectional Phillips-I2C recommended ckt. type.
(Not needing the bi-dir part, but anyway.)
- 3V5VLS.jpg (38.78 KiB) Viewed 291 times
- dastels
You actually do need the bidirectional part.
How is it wired?
How is it wired?
- dx160
You're right, of course - the I2C is bi-dir.
How is it wired?
The LV# pads get the ESP32 and the corresponding HV# pads go to the appropriate 1947 pin/s.
(The 'HV' gets 5V and 'LV' gets 3V3 from the ESP32.)
This is what I'm doing with --
How is it wired?
- ESP32_1947_bb_01.jpeg (224.16 KiB) Viewed 277 times
- dastels
Grounds of the two boards connected and to both grounds of the level shifter?
- dx160
Oh yes, definitely
- dx160
Dave (dastels) --
Here is a DWG of my circuitry / wiring.
- ESP32_1947_DWG.png (241.54 KiB) Viewed 253 times
- dastels
Let's recap:
- tft shield directly on UNO works
- tft shield wired top UNO works
- tft shield wired to ESP32 (using 3.3v->5v shifters): SPI (display) works but I2c (touch) doesn't
Right?
What you're doing looks reasonable, but I'm wondering if the 3.3v -> 5v -> 3.3v level shifters (the latter are on the shield) are messing up the I2C signals.
You might want to look for a tft+touch that is 3.3v compatible.
Right?
