mindfulness vibrating bracelet with random time
Wearable electronics: boards, conductive materials, and projects from Adafruit!
bozzaglia
Post by bozzaglia »
I am completely new and would like to build a wearable circuit that I can program to vibrate at random time within a certain interval (i.e. one randomly timed vibration every 30 minutes interval.
I have seen a similar project based on the GEMMA platform, but it didn't have the random time function.
Can you point out the easiest way to do it?
Thanks in advance!
Angelo
Re: mindfulness vibrating bracelet with random time
There is a random function in the Arduino library. It works on the Gemma too: https://www.arduino.cc/reference/en/lan ... rs/random/
bozzaglia
Post by bozzaglia »
Thanks! Forgive my ignorance: I understand the GEMMA comes preloaded with CircuitPython, so I would have to wipe it to use Arduino?
Another thing: I see the “random” function provides numbers, how can I turn it to times?
Thanks!!
CircuitPython has a random function also: https://docs.circuitpython.org/en/lates ... index.html
Time is just numbers too. The Python code from that project defines "on_time" as 2 seconds. You can substitute a random number for the "2";
https://learn.adafruit.com/buzzing-mind ... ython-code
on_time = 2     # Vibration motor run time, in seconds
bozzaglia
Post by bozzaglia »
Ok, I think with the help you are providing I can just use the existing bracelet project and tweak the code to do what I need.
Please let me know if I am abusing of your kindness: the current code is:
interval = 60 # Time between reminders, in seconds
I think I need to keep the 2, as it is the vibration duration, and change the 60 into a random number.
However I want to have ONE random motor run EVERY 30 minutes, so I guess the code becomes a little more complicated, because the interval needs to vary randomly but looking at an active window between 07:00 and 23:00 I only want to get 2 alarms every hour. I post a screenshot of the app I currently use on my iPhone.
Any idea about how to code it?
It would save me hours of research...
I'm not much of a Python programmer. But I think a reasonable approach would be to set your interval to 30 minutes. When the interval passes, instead of starting the buzzer, generate a random delay between 0 and 30 minutes. When that delay expires, you can start the buzzer.
bozzaglia
Post by bozzaglia »
Thanks again! I was able to get some code also from the stackoverflow forum. I'll post it at the end in case it helps somebody else.
I was wandering if this would also work on the Trinket, which I understand is slightly smaller than the Gemma.
import datetime
from random import randint
begin = datetime.datetime.strptime("07:00", "%H:%M")
end = datetime.datetime.strptime("23:00", "%H:%M")
delta = datetime.timedelta(minutes=30)
r = []
while begin <= end:
r.append(begin + datetime.timedelta(seconds=randint(0, 1800)))
begin = begin + delta
print(r)
The Trinket & Gemma are essentially identical circuits. The Trinket is designed for minimum size. The Gemma has a larger form-factor to accommodate the larger holes needed for use with conductive thread on wearable projects.
bozzaglia
Post by bozzaglia »
Ok great! Now I am looking at the battery.. what is the smallest coin battery holder that I can accommodate in a small case with the trinket or Gemma? (I saw the 3D printable cases)...
We have a 12mm holder: https://www.adafruit.com/product/1868
The one with a built-in switch is a bit larger: https://www.adafruit.com/product/1867
bozzaglia
Post by bozzaglia »
Great! For some reason I hadn’t been able to find those on your website.
Is there a tutorial showing how to connect them to the GEMMA/TRINKET?
I’d like to position it on the top or bottom, in order to gain only a little thickness but no length or width, so I can put everything in a small case.
Connect the "-" pin to "GND". And connect the "+" pin to "BAT" on the Trinket or "VOUT" on the Gemma.
bozzaglia
Post by bozzaglia »
Ok and these connections can be done through the pitch breakout pins provided with the battery card or I have to solder wires?
You would need to solder some wires.
bozzaglia
Post by bozzaglia »
Got it! Finally I am buying the components. The only one I am having trouble with is the “~220-1K ohm resistor”. It’s not on your website and if I look it up I get both 220 ohm and 1k ohm resistors. Which one is it?
Return to “Wearables”
