Controller for wifi project
raysblog
Post by raysblog »
I'm planning an installation that will consist of several disconnected strands of neopixels. Each neopixel strand will have a dedicated controller that needs to be sitting on a wifi network.
I see lots of options for controllers that are wifi enabled, and some pretty big price differences. Any recommendations?
Needs to:
- Support CircuitPython, including the wifi support
- Be reasonably inexpensive (less than $20 is ideal)
- Be able to drive strands neopixel strands of up to 10 feet in length
- Be powered by power cable
Thanks.
neradoc
Re: Controller for wifi project
Post by neradoc »
Hi, any requirements on the power cable ?
All boards can be powered by USB, most Adafruit boards can be powered by the 5V or Bat pin (if any) when not on USB.
Few boards have a dedicated power plug (the Metro are the only ones I can think of).
To drive a neopixel strand I would use a QT PY ESP32-S2. There's also a version with external antenna.
The C3 version is cheaper, but support is still alpha in Circuitpython.
raysblog
Post by raysblog »
Thanks for the response.
No requirements on power cable. So long as I could use a USB plug adapter to plug directly into an outlet, that definitely works!
Couple quick followups:
1. If I get the stock QT Py ESP32-S2, I assume I don't need the antenna? Does the antenna just give extra wifi range?
2. Do you know how many neopixels this QT Py can drive?
neradoc
Post by neradoc »
Software-wise, there's 2MB of PSRAM, you can drive a large number of neopixels with that.
Powering them depends on the total number, but that's nothing special to the QT PY.
I find the builtin antenna to be sufficient for my use, but I can't talk for your setup. That's always an unknown with wifi.
Return to “Wireless: WiFi and Bluetooth”
