SSD1306 library for Wemos D1 mini (64x48)
sekramer10
Post by sekramer10 »
I'm getting an error when compiling the example "ssd1306_64x48_i2c.ino" from the "Adafruit_SSD1306_Wemos_Mini_OLED" library, v1.1.2.
The error is:
"Height incorrect, please fix Adafruit_SSD1306.h!"
This comes from lines 55-57 in the sketch which are:
#if (SSD1306_LCDHEIGHT != 48)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
I'm not sure how to modify the sketch or library files so that it works correctly. I tried the declaration "Adafruit_SSD1306 display(64,48)" it compiles but the output is wrong. I have the 64x48 wemos d1 mini shield on a esp8266 module.
adafruit_support_carter
Re: SSD1306 library for Wemos D1 mini (64x48)
Is that this library?
https://github.com/stblassitude/Adafrui ... Wemos_OLED
If so, that's not an Adafruit library. It's someone's fork of an Adafruit library.
The Adafruit SSD1306 Arduino library is here:
https://github.com/adafruit/Adafruit_SSD1306
sekramer10
Yes I have found out that your library works better. Thanks.
Return to “Other Arduino products from Adafruit”
