Serial connection and USB
K212
Post by K212 »
I want to connect 2 Itsy Bitsy boards (ProductID: 3677) in serial, having one of them powered with the USB cable, and power the 2nd board through the 1st board.
Wired up both, and got the powering part working. I have an LCD connected to each boar, and that's working fine.
(Both boards are interconnected using USB C to USB C breakout boards.)
However, I can't seem to get them to talk to each other.
On the sender side, I trigger the following code when I press a button, and I can see that the LED is switched on.
Serial.write(1);
digitalWrite(LED, HIGH);
On the receiving side, I have the following code.
if (Serial.available() > 0)  {
    char number = Serial.read();
The inner part of the if statement is never executed, as the LED never turns on.
I have tested putting the LED logic outside the if statement to check that everything is wired correctly, and it is.
The boards have their 5V and GND pins connected to each other and the RX of one board to the TX of the other board and vice versa.
I have the following hypothesis, based on things I read online, but unsure if it's correct;
RX/TX pins are even used for the USB serial connection between the PC and the board connected to it, and RX/TX can therefore not be used for what I'm trying to do?
Some boards seem to have additional serial ports on other pins, and in those cases you would use Serial1, Serial2, etc?
Is this correct? Is it impossible to use the RX/TX pins for other stuff if you're powering the board through USB?
If so, how do I get around the problem?
I don't need to be able to use the use the serial port monitor, I can debug using the LCDs I have connected to each board.
The boards will act as an HID (split) keyboard.
Re: Serial connection and USB
The 32U4 is a native USB device and the primary serial port "Serial" is the USB/Serial port. The Rx and Tx TTL Serial pins are accessed via "Serial1": https://learn.adafruit.com/introducting ... ns-2979410
K212
Post by K212 »
If I use Serial1, it doesn't seem to work. If I use a single board and run the following code, it prints
Nr of bytes: 63
Value read: 0
Nr of bytes: 63
Value read: 0
Nr of bytes: 63
Value read: 0
Nr of bytes: 63
Value read: 0
  Serial.begin(9600);
  Serial1.begin(9600);
   while (!Serial) ;
   delay(3000);
  readData();
  delay(1000);
void readData()
  int nrOfBytes = Serial1.available();
  if (nrOfBytes > 0)
    Serial.print("Nr of bytes: ");
    Serial.println(nrOfBytes);
    int value = Serial1.read();
    Serial.print("Value read: ");
    Serial.println(value, DEC);
Please post photos showing how you have everything connected. And post the code you are running on each board.
K212
Post by K212 »
The full code is above, and I'm running that on a single board connected to my PC without any other connections
K212
Post by K212 »
Also, I tested running the code on both boards, I get the exact same behaviour
You cannot expect meaningful serial data with floating inputs.
K212
Post by K212 »
By floating inputs, do you mean the RX and TX pins aren't connected to anything?
Yes. The Rx pin will be in high-impedance mode and with no connection will be susceptible to EMI.
K212
Post by K212 »
Alright, I will try again connecting it to another board. The reason I did it this way was that I was having similar issues and I wanted to try to reproduce it with minimal components and code, but I will use 2 boards again then
K212
Post by K212 »
Now I read 0 bytes instead...
Code below (just switching the isSender flag to true/false depending on which board it is)
bool isSender = false;
int nrOfTimesSent = 0;
  Serial.begin(9600);
   while (!Serial) ;
   while (!Serial1) ;
   delay(3000);
   Serial.print("Start ");
   Serial.println(isSender, DEC);
  if (isSender)
    sendData();
    delay(3000);
  else
    readData();
    delay(1000);
void sendData()
  Serial1.write('1');
  nrOfTimesSent++;
  Serial.print("Sent ");
  Serial.println(nrOfTimesSent, DEC);
void readData()
  if (nrOfBytes > 0)
Result:
Start 0
Nr of bytes: 0
Nr of bytes: 0
Nr of bytes: 0
Nr of bytes: 0
Nr of bytes: 0
Nr of bytes: 0
Nr of bytes: 0
Nr of bytes: 0
I can't seem to attach an image, it just complains it's too large.
Either way, the connections are like this;
Board 1 Board 2
RX (0) TX (1)
TX (1) RX (0)
5V 5V
GND GND
Receiver board is connected through USB to my PC. Sender board is powered by receiver board.
Are both boards connected to USB? Your code as written would require both boards connected to USB.
K212
Post by K212 »
No they are not, only the receiver. Why does the code require both of them to be connected to USB?
K212
Post by K212 »
Nvm, I got it, due to the
while (!Serial) ;
Return to “Arduino”
