We're going to use the 24LC32 4KByte EEPROM module for rapid prototyping in a new project. We've been able to download schematics & layouts for 10 of the other stemma modules the project will be using but there doesn't seem to be either a layout or schematic for the 24LC32 4KByte EEPROM. Maybe we're missing something, if so could someone point me to a place on the adafruit website that has this info?
All our mechanical guys need at the moment are the board dimensions & mounting hole placement dimensions so they can get on with package design. If only that's available, then that's sufficient. As lead EE on the project having the schematic for reference would be great (PDF/JPEG/PNG form is fine).
We'll order the boards with or without the specs and can get the dimensions when they arrive but having them ASAP would be highly desirable!
Thanks any assistance!
24LC32 4KByte EEPROM - missing board layout or dimensions
- billkru
- adafruit_support_carter
Re: 24LC32 4KByte EEPROM - missing board layout or dimensio
The PCB files are here:
https://github.com/adafruit/Adafruit-24LC32-PCB
This guide discusses how to view these files using Eagle:
https://learn.adafruit.com/accessing-an ... s/overview
and covers dimensional info:
https://learn.adafruit.com/accessing-an ... ional-info
However, this:
However, this:
should be common to other STEMMA QT breakouts of the same size.All our mechanical guys need at the moment are the board dimensions & mounting hole placement dimensions
