PN532 Board not found
Jdoval
Post by Jdoval »
I purchased a PN532 board on July 28, Order: 2893005-4996777903
I connected to an Arduino Uno using the instruction provided here:
https://learn.adafruit.com/adafruit-pn5 ... out-wiring
I'm using the Adafruit sketch "readMifare" to capture board information, but with no luck. It continues to show "Didn't find PN53X board"
Below is an image of the wiring:
Wiring image
Wiring image
To debug, I have also connect to a Due w/o the 4050 --> same results
I also connected to linux virtual box using libnfc --> same results
Any help would be great. Thanks!
dastels
Re: PN532 Board not found
Post by dastels »
Can you post clear closeups of your soldering of the headers?
Have you tried changing the wires or position on the breadboard?
Jdoval
Post by Jdoval »
Here are the images of the solder.
I have used different leads and test board locations with no luck
dastels
Post by dastels »
I can't really see the soldering. A tighter closeup on the soldered side of the headers, please.
Jdoval
Post by Jdoval »
dastels
Post by dastels »
Thanks. It doesn't look horrible. But the few at the 5v end look a mess and possibly have the potential for shorts. I suggest retouching all the connections and cleaning it up a bit.Make sure you have good solder joints with no splatter ot bits of solder around them.
The fact that you've tried different controller, wires, and protoboard locations strongly points to the PN532 board.
Jdoval
Post by Jdoval »
Retouched and cleaned. Same result.
dastels
Post by dastels »
I'm thinking it's a bad board.
Please email [email protected] with a link to this thread, your order number, and request the replacement of one PN532 NFC/RFID controller breakout board - v1.6.
Return to “Itsy Bitsy Boards”
