I'm trying to get Arduino IDE to run this code off the board so I can monitor it live below:
#Created by: Bryant Forsythe
#2/26/2021
#Alchemy Escape Rooms
#Cauldron Prop
import time
import neopixel
import board
import digitalio
# Create digital input with pull-up resistor
# for break beam sensors.
#Beam 1 Orange Wire
break_beam1 = digitalio.DigitalInOut(board.A1)
break_beam1.direction = digitalio.Direction.INPUT
break_beam1.pull = digitalio.Pull.UP
#Beam 2 Purple Wire
break_beam2 = digitalio.DigitalInOut(board.A2)
break_beam2.direction = digitalio.Direction.INPUT
break_beam2.pull = digitalio.Pull.UP
#Beam 3 Green Wire
break_beam3 = digitalio.DigitalInOut(board.A3)
break_beam3.direction = digitalio.Direction.INPUT
break_beam3.pull = digitalio.Pull.UP
#Beam 4 Yellow Wire
break_beam4 = digitalio.DigitalInOut(board.A4)
break_beam4.direction = digitalio.Direction.INPUT
break_beam4.pull = digitalio.Pull.UP
#Beam 5 White Wire
break_beam5 = digitalio.DigitalInOut(board.A5)
break_beam5.direction = digitalio.Direction.INPUT
break_beam5.pull = digitalio.Pull.UP
# Main loop runs forever and prints a message once a second
# while the sensor is blocked/broken.
count = 0
while True:
if not break_beam1.value:
# Break beam input is at a low logic level, i.e. broken!
print('Beam 1 is broken!')
time.sleep(1.0) # Delay for 1 second and repeat again.
if not break_beam2.value:
print('Beam 2 is broken!')
if not break_beam3.value:
print('Beam 3 is broken!')
if not break_beam4.value:
print('Beam 4 is broken!')
if not break_beam5.value:
print('Beam 5 is broken!')
Arduino: 1.8.20 Hourly Build 2022/04/25 09:35 (Mac OS X), Board: "Adafruit ItsyBitsy M0 Express (SAMD21), Small (-Os) (standard), Arduino, Off"
fork/exec /Users/JoshuaClifford/Library/Arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4/bin/arm-none-eabi-g++: no such file or directory
Error compiling for board Adafruit ItsyBitsy M0 Express (SAMD21).
