Yes, coming out of deep sleep does a powerup of the MCU, which means that the CircuitPython runtime restarts and goes through the boot process (executing boot.py, etc). That's the thing with a deep sleep... the chip is powered down to save as much as possible.
You could flip the logic of the mode switch so that you need to hold it pressed to write to CIRCUITPY from the PC. That way it will come up able to write to the drive from CP normally.
buzzing mindfulness bracelet code plus some new functions
- dastels
- bozzaglia
Re: buzzing mindfulness bracelet code plus some new functions
Flipping the logic sounds great.
Is this the code I have to change in the BOOT.PY file?
Should I write “Pull.DOWN” instead of “Pull.UP”?
switch.direction = digitalio.Direction.INPUT
switch.pull = digitalio.Pull.UP
- dastels
No, that part is good. Negate the switch value for remounting:
storage.remount("/", not switch.value)
- bozzaglia
Update after a while:
finally I received the bluetooth board. However... the Italian company I purchased from sent me the wrong board: I had ordered a QY PY ESP32-S3 but they delivered an ESP32-C3 instead.
Besides the courier threw the package in my garden and my dog chew at it and broke the stemma connector (which I don’t need) and apparently nothing else.
Today I soldered the circuit and powered it up and noticed the following issues:
1) my pc does not see the board unless it is already powered by the battery and even in that case does not recognize it.
2) the battery doesn’t get charged through the BFF when the board is plugged to the pc (this time I put the boards side to side and I’ve only connected the ground and 5v pins as you suggested).
I’ve seen the C3 doesn’t have native USB and was wandering if this is the reason...
- dastels
Who knows what damage your dog inflicted on it! Sounds like it might have damaged the USB circuitry ot connector.
- bozzaglia
I have been trying to find a new board but it seems very hard in Europe at the moment and shipping from the US is very expensive (50$!)
The only model I was able to get now is the QT PY ESP32-C3, which I understand cannot do circuit python but only micro python...
Would it be very complicated to convert my code to micropython?
- dastels
I have no idea. But CircuitPython is a derivative/extension of Micropython so it shouldn't be too bad. Library support may be an issue.
- bozzaglia
Ok I had a look at the micropython setup on the ESP32-C3 page and it looks like I would need to do more studying and it would require me an additional effort which I am not motivated to do at the moment...
I was able to find the ESP32-S2 from Germany but I am also considering to go all the way and pay the 50$ shipping cost to get the S3 from Adafruit... I just need to make sure of something first: I prefer the S3 over the S2 because I am assuming that the Bluetooth (which only the S3 has) would allow my iPhone 6 to see and read the .txt file where the code logs my button feedback, whereas the WiFi (which also the S2 has) would not allow my phone to do the same thing... is this correct?
- dastels
I thin kBT is more likely to let you do that, yes. You might have to code it to do that, though. Not something I've had to do.
Have you looked at other European distributors? https://www.adafruit.com/distributors#Europe
- bozzaglia
Ok if I wanted to code the BT where would I find a guide? I looked on the S3 board page but couldn’t find anything on this subject.
Regarding the European distributors, I had already tried almost all the Italian ones with no luck... it seems nobody has it on stock and they don’t want to order it...
I’ve sent some more emails, let’s see what comes out!
- dastels
I would start by looking at the bluetooth based project guides https://learn.adafruit.com/search?q=bluetooth. They might have things you could use.
- bozzaglia
Ok I started looking at the BT projects and reading the BT guides. One thing I noticed is that QT Py boards are not listed among those compatible with the Bluefruit Connect App (see screenshot).
Is there any way you can find out if I can really implement what I’d like to do, so I don’t risk spending a lot of money to ship the S3 board for nothing?
BTW today one of the Italian distributors got back to me and told me that Adafruit is not allowing any distributor to get that particular board (maybe because it is rather new?) and it can ONLY be purchased through your store...
- F9B87D55-B734-4EC8-B2F2-0D9E5880665D.png (244.6 KiB) Viewed 121 times
- dastels
I'll ask. That list might be out of date. As for the distributor... it might be due to licensing or chip availability.
- adafruit2
you can use nRF52840 boards, those have the best BLE support
- bozzaglia
Thanks for the advise. I understand the recommended board is of the Feather type, so the size is probably a little too big for my project: feather is 51mm long while a QT PY plus BFF charger side-by-side measure around 36mm.
So I would lean towards sticking with the QT Py. Should I assume the QT Py S3 BT support is not sufficient to implement file reading from smartphone?
