Using Stepper motors to lift a model bridge
- roadshark
Re: Using Stepper motors to lift a model bridge
Have just posted in previous post some motor specs.
- roadshark
Serial.println(stepperLH.currentPosition()); Yep at the end of the bridge lift stepper LH is at 800!
Please post your full code.
- roadshark
So I decided to do this, int buttonState = digitalRead(bridgeDeckDown); Read to see if the button is registering.
I placed the read in the code here
When I run the code I see the steps appear on the serial monitor and stop at 800. But the button state does not appear in the monitor. It is like the program gets stuck in the bridge lift code and will not exit??? or I probably have not placed the read button state in the correct place. Here is the full code.
Serial.println(buttonState);
//Moves the bridge deck down
if ((digitalRead(bridgeDeckDown))&& (stepperLH.currentPosition() == 800))
#include "AccelStepper.h"
// Library created by Mike McCauley at http://www.airspayce.com/mikem/arduino/AccelStepper/
// AccelStepper Setup
AccelStepper stepperLH(AccelStepper::DRIVER, 23, 25);
AccelStepper stepperRH(AccelStepper::DRIVER, 31, 33);
// Define the Pins used
#define home_switchLH 9 // Pin 9 connected to Home Switch (MicroSwitch)
#define home_switchRH 10// Pin 10 connected to Home switch
#define bridgeDeckUp 34// Raise the bridge deck
#define bridgeDeckDown 36// lowers deck
int outPutPins[] = {22, 24, 25, 26, 28, 30, 32, 37};// out put pins (22, 24, 26,28 used to set step rate on the MP6500. Pins 25 and 37 used to set current limit)pin 30/32 is sleep pin
int pinCount = 7;
// Stepper Travel Variables
long initial_homing = -1; // Used to Home Stepper at startup
Serial.begin(9600);
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(outPutPins[thisPin], OUTPUT);
pinMode (bridgeDeckUp, INPUT_PULLUP);
pinMode (bridgeDeckDown, INPUT_PULLUP);
pinMode(home_switchLH, INPUT_PULLUP);
pinMode(home_switchRH, INPUT_PULLUP);
digitalWrite (30, HIGH);// Enables the sleep pin on the MP6500/stepperLH
digitalWrite (32, HIGH);// Enables the sleep pin on the MP6500/stepperRH
digitalWrite (25, LOW);// StepperLH
digitalWrite (37, LOW);// StepperRH
// Pins to drive steps
//Change to HIGH OR LOW designates step rate pin 22 and 24 are for LHstepper 26 and 28 for RHstepper To speed up homing set to full step.
digitalWrite (22, LOW);
digitalWrite (24, LOW);
digitalWrite (26, LOW);
digitalWrite (28, LOW);
// Set Max Speed of each Steppers at startup for homing
stepperLH.setMaxSpeed(50.0);
stepperRH.setMaxSpeed(50.0);// Set Max Speed of Stepper (Slower to get better accuracy)
// Start Homing procedure of Stepper Motor at startup
while (digitalRead(home_switchLH) || digitalRead(home_switchRH))
{ // Move motors towards home until both switches are activated
if (digitalRead(home_switchLH))
stepperLH.moveTo(initial_homing);// homing switch on this motor should stop both motors
stepperLH.run();
if (digitalRead(home_switchRH))
stepperRH.moveTo(initial_homing);// Set the position to move to
stepperRH.run();
initial_homing--; // Decrease by 1 for next move if needed
stepperLH.setCurrentPosition(0); // Set the current position as zero for now
stepperRH.setCurrentPosition(0);
stepperLH.setMaxSpeed(25.0); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperRH.setMaxSpeed(25.0);
digitalWrite (22, LOW);//Sets the step rate high for accuracy sgtep set at one eighth.
initial_homing = 0;
// Move motors AWAY from home until both switches are deactivated and set position to 0.
while (!digitalRead(home_switchLH) || !digitalRead(home_switchRH))
if (!digitalRead(home_switchLH))
stepperLH.run();
if (!digitalRead(home_switchRH))
stepperRH.run();
initial_homing++; // Decrease by 1 for next move if needed
//stepperLH.setMaxSpeed(200.0); // Set Max Speed of Stepper (Faster for regular movements)
//stepperRH.setMaxSpeed(200.0);
digitalWrite (30, LOW);// Disables the sleep pin on the MP6500/stepperLH
digitalWrite (32, LOW);// Disables the sleep pin on the MP6500/stepperRH
void loop() {//The bridge deck lift
if ((!digitalRead(bridgeDeckUp)) && (stepperLH.distanceToGo() == 0))
delay(1000);
stepperLH.setAcceleration(25.0);
stepperRH.setAcceleration(25.0);
stepperLH.moveTo(800);//Deck moves to top and stops.
stepperRH.moveTo(800);
while ((stepperLH.distanceToGo() != 0) || (stepperRH.distanceToGo() == 0))
stepperRH.run();
stepperLH.run();
//Bridge deck at top so turn off motors.
digitalWrite (30, LOW);// Enables the sleep pin on the MP6500/stepperLH
digitalWrite (32, LOW);// Enables the sleep pin on the MP6500/stepperRH
stepperLH.moveTo(0);//Deck moves to bottom and stops.
stepperRH.moveTo(0);
stepperRH.run();
stepperLH.run();
//Bridge deck at bottom so turn off motors.
You are reading button-state at global-scope. You need to move that inside your loop:
And this will get you stuck in the lowering loop:
You need a '!=' on the RH side of that too.
- roadshark
if ((digitalRead(bridgeDeckDown)) && (stepperLH.currentPosition() == 800))
while ((stepperLH.distanceToGo() != 0) || (stepperRH.distanceToGo() != 0))
stepperRH.run();
stepperLH.run();
I put the button read inside the bridgeDeckDown Loop. After the bridgeDeckUp Loop completes I press the button but nothing appears in the serial monitor. To my thinking there are 3 possibilities. 1. The button is not functioning (Tested this out by reversing the buttons so that button was now deckBridgeUp. It worked. The pin 36 in the mega was faulty so I changed to pin 38, still no go. 2. The position of the stepper is not really at 800. The serial monitor shows it is. 3. The code is not getting to that point and is hanging in the bridgeDeckUp loop?
Did you fix this too? See the second part of my previous post.
- roadshark
yep.
stepperRH.run();
stepperLH.run();
stepperRH.run();
stepperLH.run();
The loop part of the deck-up code is just this:The code is not getting to that point and is hanging in the bridgeDeckUp loop?
stepperRH.run();
stepperLH.run();
Is it still printing out the current position? Post a sample of the output.
- roadshark
I even tried this by just reading if the button was pressed without checking the stepper
if (!digitalRead(bridgeDeckDown))
still no go.
here is the serial monitor. Ends on 800 and nothing else
still no go.
- monitor.jpg (167.53 KiB) Viewed 123 times
We need some more diagnostic output:
Print both LH and RH positions in your while loop, and another line when you exit the loop:
stepperRH.run();
stepperLH.run();
Serial.print(stepperLH.currentPosition());
Serial.print(" - ");
Serial.println(stepperRH.currentPosition());
Serial.println("Bridge is down!");
- roadshark
YEP IT SHOWS THE BUTTON STATE
- monitor2.jpg (189.38 KiB) Viewed 121 times
OK. Now add the same diagnostic output to your 'down' loop so we can see what it is trying to do.
- roadshark
Hi Bill, Not sure what telepathic communication you are doing with my pc but the code u sent I placed in my code and everything works. OMG it was just looking at the serial monitor?? I am perplexed to say the least. Just like the kid that fools around in class, when you take a close look at them they behave?? Thanks for your mammoth efforts in assisting me!
Here are the specs of the new motors though the threaded rod is a bit large in diameter.
tepper Motor Model: 17HS1538-P4170
Motor Height 40 mm
Weight 320 g
Type 2 Phases, 4-Wire
Torque (Rated, Manufacturer) 0.45 Nm
Step Angle 1.8º
Operating Voltage 12 V (Recommended)
Current (Rated) 1.68 A/Phase
Connector Type XH2.54 (4-pin)
Do I have to alter the current limiting?
I do believe it would be wise to put a fail safe switch to cut the power (or use the reset pin) in the case the mega has a problem....at the top of the and the bottom. It would be best to have this not attached in any way to the processor I guess.
In the actual protype of the bridge the ships apparently signal to the bridge operator with their ships horns. Then the train signals further up the track would turn red (quite a way especially with your American freight trains). A siren sounds and the bridge lifts. I plan to use the music maker shield to play the sounds of the electrical motors and the clanking of the bridge as it lifts including the siren sounds. I am not sure if they have boom gates across the lines in front of the bridge or not. Was the bridge you showed me a train or traffic bridge? Might have to include servos to operate the boom gates. I hope the mega can handle all this.
Motor Height 40 mm
Weight 320 g
Step Angle 1.8º
Good to hear that is working for you now.
Those motors are rated for 1.68A/phase. So your 1.5A current limit should be fine. And putting them to sleep between moves should keep them running cool.
You won't find boom-gates on railroad bridges like the Joliet or the Cape Cod Canal bridge I linked earlier. Unlike automobile drivers, train engineers are less likely to disregard the signals.
