QTPY 2040: DPS310 Sensor: Error: 'busio' is not defined
For Adafruit customers who seek help with microcontrollers
TitaniumTeeth
Post by TitaniumTeeth »
I have an Adafruit QTPY 2040 connected to a DPS310 Pressure sensor via the Stemma QT port with a cable.
I tried running the sample code provided:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
from adafruit_dps310.basic import DPS310
i2c = busio.I2C(board.SCL1, board.SDA1)
dps310 = DPS310(i2c)
while True:
    print("Temperature = %.2f *C" % dps310.temperature)
    print("Pressure = %.2f hPa" % dps310.pressure)
    print("")
    time.sleep(1.0)
I even update the i2c = busio.I2C(board.SCL1, board.SDA1) to SCL1 and SDA1 for the non-board i2c connection (found that in a adafruit forum post)
Still no luck running the code.
I keep getting the error:
File "code.py", line 8, in <module>
NameError: name 'busio' is not defined
I checked and I have the DSP310 modules load in the lib directory.
Any help would be appreciated.
Dps310 screenshot.jpg (31.77 KiB) Viewed 110 times
Reason: Add code tag
dastels
Re: QTPY 2040: DPS310 Sensor: Error: 'busio' is not defined
Post by dastels »
You need to
import busio
TitaniumTeeth
Dave, Thanks!
I added: import busio and it worked.
It may be useful to put that in the sample code for this sensor found here:
https://learn.adafruit.com/adafruit-dps ... cuitpython
dastels
Post by dastels »
I don't see where that sample code uses busio.
adafruit2
Post by adafruit2 »
you can also use `board.STEMMA_I2C()`
Return to “Microcontrollers”
