Hi there,
I am preparing a workshop for the local university and am planning to use the Trinket M0 with maker.makecode.com.
In my test I couldn't get the "show data device" option, which opens the console, reliably.
Sometimes it would appear, but most of the times it wouldn't.
The webUSB connection works in so far, that I can pair the device and transfer the file directly to it without any problems.
I tried it with a PC (Windows 10, newest chrome browser) and a MacBook (also with the newest chrome browser).
I followed the instructions here, including updating the bootloader: learn.adafruit.com/makecode/webusb
Since the students will have to work with different sensor, it is quite essential to have a working console...
Is there anything I can try to make it work?
Best wishes,
David
Trinket M0 MakeCode Console
- mikeysklar
Re: Trinket M0 MakeCode Console
David,
Have you tried using a powered USB 2.x hub? I know you have a working USB connection, but we have had threads in the forums about different configurations to bring up a reliable console. Some USB 3 configurations or under powered USB ports seemed problematic.
- _david_f
Hi mikeysklar,
thank you for your help.
On Windows I figured out how to get it working:
1. Connect and pair USB device
2. Upload code that prints to console
3. Connect and pair again (there is a new USB device showing up)
4. Now the “show data device” option shows up
On Mac I haven’t found a solution and would be very happy for any help!
- mikeysklar
There is a little comment on a BBC:microbit MakeCode page that might be relevant to try on MacOS:
https://support.microbit.org/support/so ... leshootingYou can also try reseting the connection in MakeCode by removing the pairing in the browser and reloading the page. You will then need to pair again using the Download button
- _david_f
Unfortunately this didn't work either :(
As a workaround I wanted to use the terminal to print out the console, but the serial port only appears in bootloader mode.
When the code is running the serial port disappears.
This seems related to this viewtopic.php?p=855981&hilit=console#p855981
Is there no way of using the usb serial connection with makecode?
- mikeysklar
It might be necessary to create a new issue that is MacOS specific.
It looks like the changes suggested in this issue on the pxt-adafruit github repo have been incorporated, but maybe it will be of some value to try the suggestions if they are still valid:
https://github.com/microsoft/pxt-adafruit/issues/991Try this beta editor : https://makecode.adafruit.com/?webusb=1#editor
After you get to that URL page then click IMPORT and put in this URL share link: https://makecode.com/_4dER7s9CcT9s
Then plug in your CPX and click the gear icon upper right and click "Pair device" and see if that consistently shows the console device output to your computer screen. Let me know if it does not work for you.
- _david_f
Thanks mikeysklar, in the end I just bought a couple of USB-TTL converters.
A bit more to setup, but it is working reliably.
Cheers, David
Cheers, David
