ADS1115 banana pi zero python3
lucasgeo
Post by lucasgeo »
I try to use:
pip3 install adafruit-blinka
pip3 install adafruit-circuitpython-ads1x15
I have success ads1115 in raspberry pi zero, but dont work in banana pi zero.
Return erro in import board in python:
  File "testes.py", line 1, in <module>
    import board
  File "/usr/local/lib/python3.5/dist-packages/board.py", line 204, in <module>
    raise NotImplementedError("Board not supported {}".format(board_id))
NotImplementedError: Board not supported None
In file /usr/local/lib/python3.5/dist-packages/board.py in raspberry pi zero, board_id is 'RASPBERRY_PI_ZERO'
but in Bananapi zero board_ir is NONE
adafruit_support_mike
Re: ADS1115 banana pi zero python3
The code that handles I2C communication starts by calling a function that looks for a board ID, then uses that to find the I2C interface the device uses. The error message you posted says the code couldn't find a board ID or I2C interface for the Banana Pi.
Check to see if you can find a CircuitPython port for the Banana Pi.
lucasgeo
Post by lucasgeo »
Yes, but i2c existis, i check with i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Same as the raspberry pi zero, but in raspberry is i2cdetect -y 1
`i2cdetect` isn't written in CircuitPython. It's written in C using a library that already knows what I2C port to use.
The fact that CircuitPython can't locate the I2C interface doesn't mean there is no I2C interface. It means a config file with information like "what I2C interface should I use?" is missing. To get that config file, you need to find a version of the CircuitPython core libraries configured for the Banana Pi.
