Question about the Powerboost part used with the fairy wings project
- Froggy92030
Re: Question about the Powerboost part used with the fairy wings project
Do do I type each of the PRINT items into REPL? Or does it automatically go there when I go into REPL? When I did print("Hello, CircuitPython!") All it did was give me a line that said Hello, CircuitPython!
- Froggy92030
I tried entering the first print command in the code and this is what it shows.
>>> print("Flapping", num_flaps, "times")
File "<stdin>", line 1, in <module>
NameError: name 'num_flaps' is not defined
- dastels
Oh. Sorry, you misunderstand. I am wondering what gets output to the REPL when you run you wing code. Connect to the REPL with code.py containing your wing code. Then CTRL-D when you get the >>> prompt. That'll load and run code.py and any output from it will show up in the REPL.
- Froggy92030
Ahh! Thanks for the clarification! This is what is shows. So does this mean the code is working properly and that the problem is elsewhere?
Adafruit CircuitPython 7.3.2 on 2022-07-20; Adafruit Feather M4 Express with samd51j19
soft reboot
Code done running.
soft reboot
Code done running.
- dastels
Seeing "Code done running" is unexpected. As is not seeing any output from the print calls.
Are you sure you have the right code in CIRCUITPY/code.py? Is there also a CIRCUITPY/main.py? It looks like it's running an empty code file.
- Froggy92030
I used the project bundle and code from here. My folders on CircuitPy are set up the exact same way
https://learn.adafruit.com/animatronic- ... w=all#code
- dastels
Huh. Can you post a list (screenshot is good) of what's on CIRCUITPY?
- Froggy92030
Absolutely
- wing register.PNG (16.6 KiB) Viewed 203 times
- wing folder 2.PNG (19.98 KiB) Viewed 203 times
- first wing folder.PNG (26.24 KiB) Viewed 203 times
- Froggy92030
Last 2 screen shots
- motor.PNG (10.9 KiB) Viewed 203 times
- bus device.PNG (10.31 KiB) Viewed 203 times
- dastels
Looks as it should. Now, the contents of CIRCUITPY/code.py, please.
- Froggy92030
CIRCUITPY code
- code.py
- (1.73 KiB) Downloaded 6 times
- dastels
I'm a little baffled. The code you attached should never result in "Code done running".
You're clearly connected to the REPL on the Feather. I wonder if the following line is messing it up: Try removing it. I know it's commented, but the '\' might be confusing things.
#print(DELAY\
- Froggy92030
Giving it a try now
- Froggy92030
Ok so I made the edit you suggested and tried my servos. Still nothing. I then ran it through REPL again and got the same "code done running" result
- dastels
That's bizarre.
Add some more print calls before the loop. Before & after initializing analog_in and kit. and just befoer the loop.
