Specs on TTL Serial JPEG Camera (Product ID 397)
tyamaguchi
Post by tyamaguchi »
Not sure if this is the right spot to ask this question, but I need to know some specs about this camera (Specs on TTL Serial JPEG Camera - Product ID 397) that I can't seem to find on the datasheet. The camera lens looks like it's threaded and screwed in; is the lens removable/can it be replaced with a different lens? If so, what are the dimensions of the hole? Additionally, does Adafruit have any camera modules with IR lenses? Thanks!
Re: Specs on TTL Serial JPEG Camera (Product ID 397)
The camera takes standard 12mm threaded lenses. It is IR sensitive out-of-the-box as described in the FAQ:
https://learn.adafruit.com/ttl-serial-c ... aq-2946818
tyamaguchi
Thank you so much for your reply! What is the field of view of the lens that's in the box?
About 60 degrees.
Return to “Other Arduino products from Adafruit”
