ISO Time Timezone
- goveil1
ISO Time Timezone
I am using Adafruit IO to remotely display the status of a garage door. I subscribed to the Arduino library ISO Time feed and it works just fine, except I do not see a way using the Arduino library to indicate a timezone. Documentation says it will 'guess' based upon IP location, but I am getting UTC instead. It would be great if I could solve it and also wondering if local timezone (if I can get it!) auto-adjusts for Daylight Savings time in the zone
- mikeysklar
Re: ISO Time Timezone
I see some examples of manually overriding UTC with a few lines of code to compensate for TimeZone.
https://github.com/adafruit/Adafruit_MQ ... sp8266.ino
// set timezone offset from UTC
int timeZone = -4; // UTC - 4 eastern daylight time (nyc)
int interval = 4; // trigger every X hours
int hour = 0; // current hour
void timecallback(uint32_t current) {
// stash previous hour
int previous = hour;
// adjust to local time zone
current += (timeZone * 60 * 60);
// calculate current hour
hour = (current / 60 / 60) % 24;
// only trigger on interval
if((hour != previous) && (hour % interval) == 0) {
Serial.println("Run your code here");
- goveil1
Thanks! Pretty similar to what I ended up doing. The documentation makes it seem like you can add a timezone parameter to the Time_ISO call, but I can't figure out how.
- mikeysklar
I found this example code for getting started with Time_ISO.
https://github.com/adafruit/Adafruit_IO ... scribe.ino
// Adafruit IO Time Topic Subscription Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Adam Bachman, Brent Rubell for Adafruit Industries
// Copyright (c) 2018 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// set up the 'time/seconds' topic
AdafruitIO_Time *seconds = io.time(AIO_TIME_SECONDS);
// set up the 'time/milliseconds' topic
AdafruitIO_Time *msecs = io.time(AIO_TIME_MILLIS);
// set up the 'time/ISO-8601' topic
AdafruitIO_Time *iso = io.time(AIO_TIME_ISO);
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
while(! Serial);
Serial.print("Connecting to Adafruit IO");
// start MQTT connection to io.adafruit.com
io.connect();
// attach message handler for the seconds feed
seconds->onMessage(handleSecs);
// attach a message handler for the msecs feed
msecs->onMessage(handleMillis);
// attach a message handler for the ISO feed
iso->onMessage(handleISO);
// wait for an MQTT connection
// NOTE: when blending the HTTP and MQTT API, always use the mqttStatus
// method to check on MQTT connection status specifically
while(io.mqttStatus() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
// we are connected
Serial.println();
Serial.println(io.statusText());
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
// Because this sketch isn't publishing, we don't need
// a delay() in the main program loop.
// message handler for the seconds feed
void handleSecs(char *data, uint16_t len) {
Serial.print("Seconds Feed: ");
Serial.println(data);
// message handler for the milliseconds feed
void handleMillis(char *data, uint16_t len) {
Serial.print("Millis Feed: ");
// message handler for the ISO-8601 feed
void handleISO(char *data, uint16_t len) {
Serial.print("ISO Feed: ");
