How to find the HS code of BNO055 sensor
- Thilanka_Banuka
Yesterday I ordered BNO055 sensor from ebay and today our government ban importing long list of items. Therefore can you please tell me what is the HS code of Adafruit 9-DOF Orientation IMU Fusion Breakout - BNO085 . Then I can find if this sensor can be imported or should I cancel the order.
- adafruit_support
- Thilanka_Banuka
Re: How to find the HS code of BNO055 sensor
Is this Absolute Orientation data (Three axis orientation data based on a 360° sphere, Four point quaternion output for more accurate data manipulation) are calculated using your own algorithm? are they more accurate than using raw data from sensor and get orientation using simple calculation?
Can you send me a code to access those data. I am using Arduino UNO bord
- gammaburst
Adafruit's learning guide probably answers your questions.
For BNO055, see the first two paragraphs, and the "Arduino Code" sections:
https://learn.adafruit.com/adafruit-bno ... r?view=all
The BNO085 uses the same hardware chip as the BNO055, but contains different communication firmware and improved sensor fusion firmware. Beware Adafruit's BNO085 library is too large for an Arduino Uno. Here's the learning guide:
https://learn.adafruit.com/adafruit-9-d ... 5?view=all
If that's unclear, you're welcome to ask for clarification.
