I currently have 82 feeds running on about 25 adafruit ESP32 boards in various locations (marine vessels, some at home) The update frequency is every 60 seconds that I upload a new data value and every once in awhile I notice the update will fail. I saw on this monitor page it says "rate 60/min and current usage 39/min. If i click refresh I have seen current usage in the 50's and I am wondering am I occasionally exceeding the limit of 60 per min ? Is there a performance counter to show/confirm this or could one be added on the monitor page (max current usage) ?
thanks
IO plus usage q.
- jimk123
IO plus usage q.
- adafruitIOmonitor.png (20.35 KiB) Viewed 219 times
- brubell
- Learn User Page
Re: IO plus usage q.
There is not, but it's a good idea that I'll pass on to the rest of the development team. If you are approaching the max. data rate for an IO Plus account, it's also possible to boost the rate to something harder to exceed.
- jimk123
Thanks for the quick reply. Is that something i can do to increase the max updates per minute or does an admin need to do that ?
- brubell
- Learn User Page
You don't need an admin to do this,you may add "data rate boots" to your existing Adafruit IO+ plan by clicking “Change your IO+ plan” on your account billing page (https://io.adafruit.com/billing).
Details - https://io.adafruit.com/blog/notebook/2 ... -upgrades/
