I wish to send my cp app an mqtt message from Wippersnapper when a calculation based on the temperature and humidity of the scd40 is a certain amount. That is, an action based on a function which includes two of the properties of a component (like the scd40).
Is that possible?
If not, could I do something like write an i2c mock driver that can get the two readings?
Thank you.
Action on a function of two of the (i2c) readings?
- sketchy
- brubell
- Learn User Page
Re: Action on a function of two of the (i2c) readings?
Adafruit IO does not support actions comparing values on more than one feed (ie: humidity AND temperature from the SCD40).
As a workaround (and if you do not need a strict "AND" comparison) - you could create two actions, one to monitor the temperature feed, and one for humidity. Both would publish out to a feed (or feeds) subscribed to by the cp app.
I can add an issue to our internal tracker for this feature if this is not what you're looking for.
- sketchy
Thank you. What you advise does not meet my needs. Also, another challenge is I need a reading from another sensor to finish the function.
What I am looking for are similar to Tasmota rules: https://tasmota.github.io/docs/Rules/
All the best.
All the best.
- brubell
- Learn User Page
What does the function look like exactly? It'll give me a better idea of what we're working with here (and if its even possible)
- sketchy
Thank you for your reply!
This is the code I wrote in node-red:
var air_T = global.get("temperature");
/* Assume leaf temp is 2 degrees F less */
var leaf_T = air_T - 2;
var RH = global.get("humidity");
/* see https://www.questclimate.com/vapor-pres ... tages-vpd/ */
leaf_vpd = 3.386*(Math.exp(17.863-9621/(leaf_T+460))-((RH/100)*Math.exp(17.863-9621/(air_T+460))));
msg.payload = Number(leaf_vpd.toFixed(2));
msg.topic = "vpd"
flow.set("vpd",msg.payload)
return msg;
msg.topic = "vpd"
return msg;
