USB waterproof on a Arduino board
- erik2019
Is there any Arduino board with an waterproof USB port? Or is there a board where I can simply solder a USB port to? I need a small board.
- rooppoorali
Re: USB waterproof on a Arduino board
There is no such arduino board with waterproof UBS port. If you wish you do an underwater project with Arduino, you have to use a waterproof case.
- erik2019
The case is already waterproof, and the USB port will be visible so I can connect it without take the board out from the case. So is there a board with out an pre solder usb port. So I can solder a waterproof usb port to it?
- Franklin97355
Waterproof or water-resistant? What does the port have to withstand?
- erik2019
It needs to be able to be washed.
- Franklin97355
Can you post a picture of the case?
- erik2019
Its still in development
