My trinket works, but it also doesn't...
Upon plugging in my trinket M0, the green and red LED's turn on, the red flashes for a bit, and then it's only the green ON light. I'm not seeing the purple LED turn on, and the Arduino IDE platform can't see the trinket.
I've done the following troubleshooting:
- used different cables
- checked all connections
- reset the trinket
I have 3 trinkets; two of them are working fine (code uploaded, running my sensors just fine) but this third one is driving me up the wall. I tested all my sensors using the working Trinkets so I know the sensor isn't causing the problem. Any idea why it's able to turn on but not connect to my PC?
Trinket M0 turns on but doesn't connect to Arduino IDE
- vidagabriel
- adafruit_support_carter
Re: Trinket M0 turns on but doesn't connect to Arduino IDE
Are all 3 Trinkets the same model? The Trinket M0:
https://www.adafruit.com/product/3500
None of these are the older original Trinket?
https://www.adafruit.com/product/1500
