When trying to compile the Oled FeatherWing 128x64 example Arduino code exactly as downloaded I get the following message:
"exit status 1
Error compiling for board Adafruit Feather M0."
It doesn't even get to the stage of trying to download.
I am on Arduino IDE 1.8.12
Oled Feather example won't compile
- dastels
Re: Oled Feather example won't compile
If it can't compile (or link) here is nothing to download.
Can you turn on more verbose error reporting to see exactly what's going on? You can find the relevant checkboxes in the preferences dialog.
- robtyce
Here is the brief IDE error message for compiling the example Oled program.
Arduino: 1.8.19 (Windows 10), Board: "Adafruit Feather M0, Arduino, Off"
C:\Users\hp\Documents\Arduino\libraries\Adafruit_SH110X\Adafruit_SH110X.cpp: In member function 'virtual void Adafruit_SH110X::display()':
C:\Users\hp\Documents\Arduino\libraries\Adafruit_SH110X\Adafruit_SH110X.cpp:218:16: error: 'class Adafruit_I2CDevice' has no member named 'setSpeed'
i2c_dev->setSpeed(i2c_preclk);
C:\Users\hp\Documents\Arduino\libraries\Adafruit_SH110X\Adafruit_SH110X.cpp:231:16: error: 'class Adafruit_I2CDevice' has no member named 'setSpeed'
i2c_dev->setSpeed(i2c_postclk);
exit status 1
exit status 1
- dastels
Make sure everything (libraries and board support packages) are all up to date.
- robtyce
Now finding that other Adafruit examples failing to compile for feather mo. SH110x and RTLIB are both latest versions. Here is RTLIB Ds3231 example error:
C:\Users\hp\Documents\Arduino\libraries\RTClib\src\RTC_DS1307.cpp: In member function 'void RTC_DS1307::writenvram(uint8_t, const uint8_t*, uint8_t)':
C:\Users\hp\Documents\Arduino\libraries\RTClib\src\RTC_DS1307.cpp:109:47: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
i2c_dev->write(buf, size, true, &addrByte, 1);
In file included from C:\Users\hp\Documents\Arduino\libraries\RTClib\src\RTClib.h:25:0,
from C:\Users\hp\Documents\Arduino\libraries\RTClib\src\RTC_DS1307.cpp:1:
C:\Users\hp\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:15:8: note: initializing argument 1 of 'bool Adafruit_I2CDevice::write(uint8_t*, size_t, bool, uint8_t*, size_t)'
bool write(uint8_t *buffer, size_t len, bool stop = true,
exit status 1
Error compiling for board Arduino M0.
exit status 1
- dastels
Did you make sure everything is up to date.
- robtyce
IDE, Board manager, Library manager show all components up to date, but no example using RTCLIB can compile, and gets "invalid conversion error indicated previously.
R. Tyce
R. Tyce
- robtyce
The RTCLIB ds3231 example will compile for arduino uno and adafruit feather 32u4 boards, but not for the Adafruit feather mo. I've been using Adalogger feather mo boards for some time now, and now have software developed a year ago for US navy installed logging systems that will no longer compile with this same error.
Robtyce
Robtyce
- dastels
Ah. It's the casting away of the const that's the issue. Unfortunately Arduino doesn't give you a lot of control over compilation.
Try adding "-fpermissive" (as noted in the error message) to the arduino preferences file:
Open the Arduino preferences dialog and click the link to preferences.txt near the bottom. Then edit preferences.txt that you find there to add the above line.
compiler.cpp.extra_flags=-fpermissive
- robtyce
After adding the -fpermissing line to the preferences file the error message for Adafruit Feather MO follows:
Arduino: 1.8.19 (Windows 10), Board: "Adafruit Feather M0 (SAMD21), Small (-Os) (standard), Arduino, Off"
C:\Users\hp\Documents\Arduino\libraries\RTClib\src\RTC_DS1307.cpp:109:18: error: invalid conversion from 'const uint8_t*' {aka 'const unsigned char*'} to 'uint8_t*' {aka 'unsigned char*'} [-fpermissive]
109 | i2c_dev->write(buf, size, true, &addrByte, 1);
In file included from C:\Users\hp\Documents\Arduino\libraries\RTClib\src\RTClib.h:25,
C:\Users\hp\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:15:23: note: initializing argument 1 of 'bool Adafruit_I2CDevice::write(uint8_t*, size_t, bool, uint8_t*, size_t)'
15 | bool write(uint8_t *buffer, size_t len, bool stop = true,
exit status 1
Error compiling for board Adafruit Feather M0 (SAMD21).
Reason: Add code tag to make more readable
- dastels
It's still flagging it as an error. Did you restart (and ideally modify the preferences file with Arduino closed as instructed in the dialog)?
- robtyce
I changed the preferences file with IDE closed, then restarted. No Joy. I would love to know if others experience this error when trying to compile the RTCLIB d3231 example for Adafruit Feather MO(SAMD21) boards, or if its just me with some problem of my own. I've a system to deliver to the US Navy in a week which depends upon the Featherwing ds3231 Precision real time clock. Testing this problem does not require any hardware, just the Arduino Ide and libraries.
Robtyce
Robtyce
- robtyce
Success! I went back to the library manager and updated every library on my system except the Adafruit playground collection, and both RTCLIB and SH110x errors have gone away. I'm not sure which library fixed the problem, as the two libraries in question were already up to date, but it is great to have a working IDE with the Adalogger Feather MO once again. Thanks for all the help.
Robtyce
Robtyce
