Adafruit RGB Matrix + Bonnet + RPi4 not responding to commands
miwu
Post by miwu »
I am currently trying to get a 64x32 RGB Matrix to display with hzeller's library. The hardware I have are:
Raspberry Pi 4 - Model B
2x 64x32 Matrix - https://www.adafruit.com/product/2279
Adafruit RGB Bonnet - https://www.adafruit.com/product/3211
I followed this guide: https://learn.adafruit.com/adafruit-rgb ... g-matrices
I selected 1. Adafruit RGB Matrix Bonnet and 2. Convenience
When I enter the command:
sudo ./demo -D0 --led-col=64 --led-chain=2 --led-slowdown-gpio=4
The results: The LEDs do not respond
Troubleshooting that I've performed:
  • I've reinstalled the OS twice (GUI/Lite).
  • Disconnected the chain and connected the Matrix one at a time.
  • I've swapped between matrixes and cables.
  • I connected 5v 4amp directly from bonnet. (5V LED is on)
  • I've used 5v 4amp and 5v 8amp power supplies.
  • I've reseated the bonnet on the rpi4.
adafruit_support_carter
Re: Adafruit RGB Matrix + Bonnet + RPi4 not responding to commands
Set back up with only a single LED matrix attached and try the following:
sudo ./demo -D0 --led-rows=64 --led-col=32 --led-gpio-mapping=adafruit-hat --led-slowdown-gpio=4
nocturne
Post by nocturne »
You've probably already checked this - but I've had issues with newer pi4's having 1-wire enabled. So I'd suggest checking (via sudo raspi-config):
- Ensure SPI is enabled
- Ensure I2C is enabled
- Ensure 1-wire is disabled
And if any of those were changed, reboot and try again.
miwu
Post by miwu »
adafruit_support_carter wrote: Thu Sep 01, 2022 12:18 pm Set back up with only a single LED matrix attached and try the following:
The Matrix continue to not display anything.
miwu
Post by miwu »
nocturne wrote: Thu Sep 01, 2022 6:49 pm You've probably already checked this - but I've had issues with newer pi4's having 1-wire enabled. So I'd suggest checking (via sudo raspi-config):
Thanks for the help. My SPI and I2C were disabled but it didn't fix the issue.
nocturne
Post by nocturne »
If those were disabled, and you re-enabled them, then I'd recommend also that you go to the rpi-rgb-matrix directory and either recompile/re-install, or re-run the overall installer script. Make sure to run that with sudo; and also look for any major compilation errors. For example - on one run, mine failed to find the g++ compiler dependencies, and thus ran, but technically failed even though the script didn't bomb out.
You have two copies of the matrix hardware. Label the matrix and ribbon cable used in the above test. Let's calls these matrix/cable 1. The other set is matrix/cable 2.
You've tested:
* ribbon cable 1 with matrix 1
Now try:
* ribbon cable 2 with matrix 1
* ribbon cable 1 with matrix 2
For each, just run the same test:
and see if any combos work.
miwu
Post by miwu »
nocturne wrote: Sat Sep 03, 2022 11:55 am If those were disabled, and you re-enabled them, then I'd recommend also that you go to the rpi-rgb-matrix directory and either recompile/re-install, or re-run the overall installer script. Make sure to run that with sudo; and also look for any major compilation errors. For example - on one run, mine failed to find the g++ compiler dependencies, and thus ran, but technically failed even though the script didn't bomb out.
Sorry for the late reply. I just tried reinstalling with the settings but it didn't work again. Also I didn't see any errors while the script was running.
miwu
Post by miwu »
adafruit_support_carter wrote: Tue Sep 06, 2022 2:06 pm You have two copies of the matrix hardware. Label the matrix and ribbon cable used in the above test. Let's calls these matrix/cable 1. The other set is matrix/cable 2.
You've tested:
Now try:
Sorry for the late reply. I jut tried these combos and I still haven't had any luck.
Just to verify behavior - all combinations result in no output on the RGB matrix?
miwu
Post by miwu »
Yes there are no behavior with any combo. I'm not sure if it matters but the Raspberry Pi 4 is from UK.
miwu
Post by miwu »
Please post a photo of your setup showing how everything is connected.
Thanks for the photos. The power cable appears disconnected. The power cables is plugged in to the matrix, but not back to the Bonnet.
