I am using the hat to control 14 servos and it seems that the kit.servo function is slow. I am using a pi 4 8gb. I have different arrays for each servo and a for loop that reads through each one and sends the position to the appropriate servo (code below is an example of how the other code is written). I designed a motion that should take 2.5 seconds and I wanted to run it at 100hz, so there are 250 data points in each array. It takes the code 0.14s to run through when only sending to one servo and then 0.4s for 3 servos. When I do the same thing for 14 servos it takes 2.47s. 250/2.47=101hz. I am approaching the point where I am reading at the limit and my delays are actually causing the code to run long (see below other code). Is there a way to speed this process up? Otherwise I will have to lower my resolution.
from adafruit_servokit import ServoKit
import time
kit = ServoKit(channels=16)
kit.servo[0].actuation_range = 140
kit.servo[1].actuation_range = 140
kit.servo[2].actuation_range = 140
val1 = [40,43.4,46.7,50,53.3,56.5,59.7,62.8,65.9,68.9,71.9,74.8,77.6,80.4,83,85.7,88.2,90.7,93.1,95.4,97.7,99.8,101.9,103.8,105.7,107.5,109.2,110.8,112.2,113.6,114.9,116,117.1,118,118.8,119.5,120,120.5,120.8,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,120.9,120.1,118.5,116.2,113.5,110.3,106.8,103.2,99.6,96.1,92.9,90.1,87.7,86.1,85.1,85,85,85,85,85,84.7,82.2,77.9,72.2,65.7,59,52.5,46.8,42.6,40.3,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40]
val2 = [40,43.4,46.7,50,53.3,56.5,59.7,62.8,65.9,68.9,71.9,74.8,77.6,80.4,83,85.7,88.2,90.7,93.1,95.4,97.7,99.8,101.9,103.8,105.7,107.5,109.2,110.8,112.2,113.6,114.9,116,117.1,118,118.8,119.5,120,120.5,120.8,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,120.9,120.1,118.5,116.2,113.5,110.3,106.8,103.2,99.6,96.1,92.9,90.1,87.7,86.1,85.1,85,85,85,85,85,84.7,82.2,77.9,72.2,65.7,59,52.5,46.8,42.6,40.3,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40]
val3 = [40,43.4,46.7,50,53.3,56.5,59.7,62.8,65.9,68.9,71.9,74.8,77.6,80.4,83,85.7,88.2,90.7,93.1,95.4,97.7,99.8,101.9,103.8,105.7,107.5,109.2,110.8,112.2,113.6,114.9,116,117.1,118,118.8,119.5,120,120.5,120.8,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,121,120.9,120.1,118.5,116.2,113.5,110.3,106.8,103.2,99.6,96.1,92.9,90.1,87.7,86.1,85.1,85,85,85,85,85,84.7,82.2,77.9,72.2,65.7,59,52.5,46.8,42.6,40.3,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40,40]
starttime = time.time()
reps=1
for x in range(reps):
for (num1, num2, num3) in zip(val1, val2, val3):
tiktokS = time.time()
kit.servo[0].angle = num1
kit.servo[1].angle = num2
kit.servo[2].angle = num3
tiktokE = time.time()
endtime = time.time()
print(endtime - starttime) #measure time to make sure matches desired run time
print("done")
if((tiktokE-tiktokS)<0.01):
time.sleep(0.01- (tiktokE-tiktokS))
