I am trying to use the Adafruit sketch written for the 10K Precision Epoxy Thermistor - 3950 NTC on the Arduino Uno - from: https://learn.adafruit.com/thermistor?view=all
I am attempting to use it on a Arduino Nano RP2040 Connect. (I've already successfully used more elementary skecthes on this board, with this 10K thermistor. They compile & read values without error.)
I copy and paste into a new sketch the code shown just after "This sketch takes those two improvements and integrates them into the demo, you will have better, more precise readings." on the respective Adafruit web page. When I compile it I get the error message " 'EXTERNAL' was not declared in this scope", with the line "analogReference(EXTERNAL);" highlighted.
I am completely new to programming, so I haven't a clue as to what's wrong. Any suggestions?
Thermistor sketch compile 'EXTERNAL' was not declared
- PL_aus
Re: Thermistor sketch compile 'EXTERNAL' was not declared
The advanced sketch uses an external source for the analog reference voltage. It looks like Arduino does not support that for the Nano RP2040 at this time:
https://www.arduino.cc/reference/en/lan ... reference/
- PL_aus
Thanks for the quick reply.
Can you suggest another approach to achieve improved accuracy?
The Arduino site says that the reference voltage is fixed:
However, you could use one of the 12-bit pins. That would give you 2 more bits (4x resolution) compared to the standard 10-bit Arduino resolution.Nano RP2040 Connect has eight analog input pins A0 to A7 and a fixed analog reference voltage of +3.3V. It has a 12-bit ADC on a fixed set of pins A4 to A7. As a result, standard Arduino calls can be used to read their values with a resolution that can go from 0 to 4095, corresponding to the ADC reading of the specific pin.
- PL_aus
