Feather M0 RFM95 not charging battery from USB port
For Adafruit customers who seek help with microcontrollers
krx7
Post by krx7 »
I have an Adafruit Feather M0 RFM95 LoRa Radio. The USB powering connection works fine and the battery 3.7V with JST connector is working too even if I disconnect the USB power connection.
However, if I connect the USB cable and the battery at the same time, the CHG LED of the feather M0 does not light up and the battery does not recharge.
Does anyone know how to fix this issue? Someone has had the same issue?
The Adafruit overview explain that:
When the USB power is powered, it will automatically switch over to USB for power, as well as start charging the battery (if attached).
I try with another feather M0 RFM95 with the same USB cable and battery, the CHG LED works and the battery is recharged.
Thanks...
dastels
Re: Feather M0 RFM95 not charging battery from USB port
Post by dastels »
You check with the other Feather with that battery when the working feather will try charging it (charge LED on)?
krx7
Post by krx7 »
This image shows the connection. I used the same cable USB and Battery.
The wires have the right orientation + and -.
dastels
Post by dastels »
Please email [email protected] with a link to this thread, your order number, and request the replacement of one Feather M0 RFM95 LoRa Radio.
Return to “Microcontrollers”
