To test and fix this issue I a made simple program so I can duplicate the defect. This program trys to get the current time every three minutes and display it on a TFT display.
My CP version is up to date and my AirLift firmware is also up to date. I wrote you in June about this issue but left the project for the summer.
Thanks for taking a look at this!
# IMPORT MODULES
import board, busio, digitalio, displayio, time, terminalio, gc, sys
from digitalio import DigitalInOut
import adafruit_requests as requests
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
from user_info2 import user_info2
from time import monotonic as now
#import adafruit_il0373
import adafruit_ili9341
from adafruit_display_text import label
from adafruit_display_shapes.line import Line
from adafruit_io.adafruit_io import IO_HTTP, AdafruitIO_RequestError
from random import randint
from adafruit_display_shapes.triangle import Triangle
import neopixel
#import supervisor
displayio.release_displays()
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
tft_dc = board.D10
tft_cs = board.D9
display_bus = displayio.FourWire(
spi, command=tft_dc, chip_select=tft_cs, reset=board.D6)
display = adafruit_ili9341.ILI9341(display_bus, width=320, height=240)
splash = displayio.Group()
display.show(splash)
BLACK = 0xFFFF00
esp32_cs = DigitalInOut(board.A5)
esp32_ready = DigitalInOut(board.A4)
esp32_reset = DigitalInOut(board.A3)
status_light = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.2)
# WIFI setup
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
# Create the displayio connection to the display pins
requests.set_socket(socket, esp)
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, user_info2, status_light)
aio_username = user_info2["aio_username"]
aio_key = user_info2["aio_key"]
io = IO_HTTP(aio_username, aio_key, requests)# Write your code here :-)
# Draw a green background
color_bitmap = displayio.Bitmap(320, 240, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0x000000 # Bright Green
bg_sprite = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=0, y=0)
splash.append(bg_sprite)
text_area1 = label.Label(terminalio.FONT, text="current_time", color=BLACK)
text_area1.line_spacing = 0.9
text_area1.scale = 1
text_area1.anchor_point = (0.5, 0.0)
text_area1.anchored_position = (148, 2)
#splash.append(text_area1)
JSON_URL = "http://worldtimeapi.org/api/ip"
response = None
def connect_to_internet():
global time_data
while True:
try:
print("Fetching json from", JSON_URL)
r = wifi.get(JSON_URL)
time_data = r.json()
r.close()
break
except (ValueError, RuntimeError) as e:
print("throwing exception\n", e)
wifi.reset()
continue
response = None
time.sleep(60)
#print(time_data)
while True:
print(time_data["datetime"])
text_area1.text = time_data["datetime"]
display.refresh()
time.sleep(180)
splash.remove(text_area1)
