Microstepping advice
kevcanni
Post by kevcanni »
I am using the motor shield to control two stepper motors.
I am controlling several components at once so I am stepping each motor one step at a time so that I can turn each motor 'simultaneously' as well as read data from a sensor between steps.
The stepper motors are turning very slowly: one step every 3 seconds. My motors use 200 steps for a full rotation. Each step is not really smooth enough for my purposes.
A very simply version of my code looks like this:
loop{
	AF_Stepper.onestep(direction, steptype)
	wait 3 seconds
If steptype is 'double' then each step is 1.8 degrees (200 steps per revolution).
What I would like to do is smooth the rotation by using microsteps, but I'm not sure how many steps a microstep is?
How many degrees will my stepper turn if I switch the steptype from 'double' to 'microstep'?
Re: Microstepping advice
With the Adafruit library, the microsteps are nominally 1/16 of a full step (0.1125 degrees).
Microsteps are achieved by modulating the current to the two windings so that the rotor is held partway between two full-step positions. So you can expect some variability in the exact angle of rotation between steps.
kevcanni
Post by kevcanni »
adafruit_support_bill wrote: Wed Sep 07, 2022 6:20 pm With the Adafruit library, the microsteps are nominally 1/16 of a full step (0.1125 degrees).
