Gyro cal - ESP32-S2-TFT compile issue
clarkj
Post by clarkj »
I'm trying to use "gyro_zerorate_simplecal" to calibrate an MPU-6050 attached to a Feather ESP32-S2 TFT, but am getting a compile error. I did manage to track down and eliminate one -- apparently a "legacy" library that had a time stamp from 2019...
Arduino: 1.8.19 (Mac OS X), Board: "Adafruit Feather ESP32-S2 TFT, Enabled, Disabled, Disabled, Enabled, TinyUF2 4MB (1.3MB APP/960KB FFAT), 240MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None"
/Users/clarkjones/Documents/Arduino/libraries/Adafruit_Sensor_Lab/examples/calibration/gyro_zerorate_simplecal/gyro_zerorate_simplecal.ino: In function 'void setup()':
gyro_zerorate_simplecal:35:9: error: 'class Adafruit_Sensor' has no member named 'printSensorDetails'
   gyro->printSensorDetails();
Multiple libraries were found for "Adafruit_Sensor.h"
 Used: /Users/clarkjones/Documents/Arduino/libraries/Adafruit_Sensor-master
 Not used: /Users/clarkjones/Documents/Arduino/libraries/Adafruit_Unified_Sensor
exit status 1
After reading the above error messages in detail, I finally got THAT error to go away. Simply renaming Adafruit_Sensor-master wasn't good enough, I had to move it to ~/Downloads to get rid of the error.
But then I started getting this error:
[96363] Error loading Python lib '/var/folders/z8/4nv7zsqj70b2ln148yhxr3n80000gn/T/_MEIQYu3oA/libpython3.8.dylib': dlopen: dlopen(/var/folders/z8/4nv7zsqj70b2ln148yhxr3n80000gn/T/_MEIQYu3oA/libpython3.8.dylib, 10): Symbol not found: ____chkstk_darwin
  Referenced from: /var/folders/z8/4nv7zsqj70b2ln148yhxr3n80000gn/T/_MEIQYu3oA/libintl.8.dylib (which was built for Mac OS X 11.0)
  Expected in: /usr/lib/libSystem.B.dylib
 in /var/folders/z8/4nv7zsqj70b2ln148yhxr3n80000gn/T/_MEIQYu3oA/libintl.8.dylib
exit status 255
/Applications/Arduino 1p8p19.app/Contents/Java/arduino-builder returned 255
Error compiling for board Adafruit Feather ESP32-S2 TFT.
Tranking down the "verbose" message, since the message is WRONG because I'm on a Mac -- (a) "File -> Preferences" doesn't exist, (b) "Arduino -> Preferences" doesn't have that option but does say that /Users/clarkjones/Library/Arduino15/preferences.txt doesn't have an entry for "compiler.verbose" but does have an entry for "build.verbose" which I changed from "false" to "true" I got the same messages as before, so tried adding "compiler.verbose=true", but that didn't seem to help either.
So at the moment, I can't get cal values for my MPU-6050...
mikeysklar
Re: Gyro cal - ESP32-S2-TFT compile issue
Post by mikeysklar »
Before we get into calibration lets make sure the following is true:
1) Can you compile and run the Basic Reading Example?
https://learn.adafruit.com/mpu6050-6-do ... le-3044805
2) When installing the libraries rather than using github version can you install the current releases through the Arduino IDE Manage Libraries?
* Adafruit MPU6050
* Adafruit BusIO
* Adafruit Unified Sensor
https://learn.adafruit.com/mpu6050-6-do ... on-3044792
3) Does the 'gyro_zerorate_simplecal.ino' compile when these are in place?
clarkj
Post by clarkj »
Since I'm not planning on doing anything else on this particular project using the Arduino interface, I decided to write a "special-purpose" code in CircuitPython to get some cal values for the MPU-6050. This took me less time than writing the Forums posting, and seems to be returning reasonable values.
Just in case someone else wants to use it, here's the code:
# Got fed up with trying to get the Arduino-based "gyro_zerorate_simplecal", so
# decided to implement it specificallly for the MPU6050 using Circuit Python
# Put into the public domain by Clark Jones, Sep. 8, 2022.
# No guarantees express or implied about the accuracy or merchantability.  Use
# is strictly at your own risk.
# It may not be exactly the same as gyro_zerorate_simplecal, but seems to produce
# reasonable results.
import time
import board
import adafruit_mpu6050
i2c = board.I2C()  # uses board.SCL and board.SDA
mpu = adafruit_mpu6050.MPU6050(i2c)
sum_x = 0.0
sum_y = 0.0
sum_z = 0.0
for idx in range(1500):
    curr_read = mpu.gyro
    sum_x += curr_read[0]
    sum_y += curr_read[1]
    sum_z += curr_read[2]
    time.sleep(0.002)  # Wait 2 mS
print(f"x_correction = {(sum_x/1500):.3f}")
print(f"y_correction = {(sum_y/1500):.3f}")
print(f"z_correction = {(sum_z/1500):.3f}")
print("Note that the correction factors will need to be SUBTRACTED from the values")
print("Correction factors are in radians/sec")
print("Also note that the Earth rotates at about 7.27E-5 radians/sec")
BTW, the comment at the end comes from a friend who worked in the satellite industry, and several years ago they'd gotten a new gyro unit in (one that had physical spinning gyros), and when they left it running on the bench for 24 hours they were at first a bit confused by the fact that it said it had rotated 360 degrees -- at least until one of them realized that the Earth, and the bench along with it, had rotated 360 degrees in space!
