"Adafruit_SPIFlash.h" works fine with my ItsyBitsy internal 2MB FLASH. Now I want to use "Adafruit_SPIFlash.h" with external FLASH chip in second SPI of ESP32-WROVER. How do I define that I have FLASH chip connected to second SPI bus?
Connections are: CLK in GPIO14, MISO in GPIO12, MOSI in GPIO13 and CS in GPIO15. Those are from ESP32 specification.
Tipo
"Adafruit_SPIFlash.h" with ESP32 second SPI
Re: "Adafruit_SPIFlash.h" with ESP32 second SPI
The Adafruiit_SPIFlash class takes the SPI interface as an input parameter:
https://github.com/adafruit/Adafruit_SP ... mp.ino#L44
Create a Adafruit_FlashTransport_SPI object for the secondary SPI interface, then feed that to the Adafruiit_SPIFlash object when you create it.
- Tipo1000
Hi Mike,
I tried below, but got an error. I can't figure out how to create object for second SPI. Somehow I should define pins or 'port' I want to use but 'HSPI' nor 'SPI2' works. So how to define it?
Below gives basically same error:
Can I use those two SPI's in the same code? I would read from data from sensor in one SPI and write to FLASH in another SPI.
Tipo
Adafruit_FlashTransport_HSPI flashTransport(15, HSPI); //HSPI pins: CLK - IO14, MISO - IO12, MOSI - IO13 and CS - IO15
//Adafruit_FlashTransport_VSPI flashTransport(5, VSPI); //VSPI pins: CLK - IO18, MISO - IO19, MOSI - IO23 and CS - IO5
Adafruit_SPIFlash flash(&flashTransport);
"flash_sector_dump_example_test1:9:26: error: 'flashTransport' was not declared in this scope
Adafruit_SPIFlash flash(&flashTransport);" and "'Adafruit_FlashTransport_HSPI' does not name a type; did you mean 'Adafruit_FlashTransport_SPI'?
Adafruit_FlashTransport_HSPI flashTransport(15, SPI2); //HSPI pins: CLK - IO14, MISO - IO12, MOSI - IO13 and CS - IO15
Tipo
- Tipo1000
Small addition to previous... I kind of understand how it's done below with "spi.h" and now trying to see how the same thing would be done with "Adafruit_SPIFlash.h":
and is setup...
Complete example for spi.h is here: https://github.com/espressif/arduino-es ... _Buses.ino
Similar example would help a newbie like me :)
/ Define ALTERNATE_PINS to use non-standard GPIO pins for SPI bus
#ifdef ALTERNATE_PINS
#define VSPI_MISO 2
#define VSPI_MOSI 4
#define VSPI_SCLK 0
#define VSPI_SS 33
#define HSPI_MISO 26
#define HSPI_MOSI 27
#define HSPI_SCLK 25
#define HSPI_SS 32
#else
#define VSPI_MISO MISO
#define VSPI_MOSI MOSI
#define VSPI_SCLK SCK
#define VSPI_SS SS
#define HSPI_MISO 12
#define HSPI_MOSI 13
#define HSPI_SCLK 14
#define HSPI_SS 15
#endif
//initialise two instances of the SPIClass attached to VSPI and HSPI respectively
vspi = new SPIClass(VSPI);
hspi = new SPIClass(HSPI);
