Recently purchased the Adafruit Feather M0 Adalogger and trying to follow the Adafruit Learn Setup. Having the following issues connecting to the board and compiling the simple Blink command.
- I'm running Arduino IDE 1.8.19
- I've copied https://adafruit.github.io/arduino-boar ... index.json to Additional Boards Manager URLs
- Loaded Arduino SAMD board, however, when I search for Adafruit SAMD nothing is found???
- I've installed the Adafruit Drivers _ adafruit_drivers_2.5.0.0.exe (screen pic below) which DOES NOT list out the Feather M0???
Any suggestions would be appreciated.
- ppecch
- Adafruit.JPG (40.85 KiB) Viewed 84 times
- adafruit_support_carter
Re: Adafruit Feather M0 Adalogger
Those seem like the correct steps. With the URL added, it should show up:
On your setup, if you do the same search, you only see the Arduino entry?
- ppecch
Correct, see my attached screen picture.
- NoAdafruit.JPG (67.09 KiB) Viewed 77 times
Weird. Are you able to open the URL in a browser? Just as a way to check that you can access it from your location:
- ppecch
Strange unfortunately it doesn't open ?
Any useful error messages being shown by the browser?
