Adafruit ImageReader with Rasberry PI Pico
wfitkin
Post by wfitkin »
It seems that the Adafruit_ImageReader library is not compatible with a Raspberry Pi Pico.
If you take a new sketch and add the following includes...
#include <SdFat.h>
#include <Adafruit_SPIFlash.h> // SPI / QSPI flash library
#include <Adafruit_ImageReader.h> // Image-reading functions
It will not compile. Just says "Error compiling for board Raspberry Pi Pico."
Very easy to replicate.
First tried the example Adafruit Image Reader Library/ ShieldILI9341.
Bottom line is that any sketch with #include <Adafruit_SPIFlash.h> and/or <Adafruit_ImageReader.h> will not compile if your board is a Raspberry PI Pico.
mikeysklar
Re: Adafruit ImageReader with Rasberry PI Pico
Post by mikeysklar »
Please enable verbose output during compilation (under Preferences) and paste in the full error you are seeing.
wfitkin
Post by wfitkin »
C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_SPIFlash\src\rp2040\Adafruit_FlashTransport_RP2040.cpp: In function 'void fl_lock()':
C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_SPIFlash\src\rp2040\Adafruit_FlashTransport_RP2040.cpp:47:3: error: 'rp2040' was not declared in this scope
rp2040.idleOtherCore();
C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_SPIFlash\src\rp2040\Adafruit_FlashTransport_RP2040.cpp:47:3: note: suggested alternative: 'p24'
p24
C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_SPIFlash\src\rp2040\Adafruit_FlashTransport_RP2040.cpp: In function 'void fl_unlock()':
C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_SPIFlash\src\rp2040\Adafruit_FlashTransport_RP2040.cpp:51:3: error: 'rp2040' was not declared in this scope
rp2040.resumeOtherCore();
C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_SPIFlash\src\rp2040\Adafruit_FlashTransport_RP2040.cpp:51:3: note: suggested alternative: 'p24'
p24
Using library Adafruit_SPIFlash at version 3.11.0 in folder: C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_SPIFlash
Using library SPI in folder: C:\Users\Wayne\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\3.2.0\libraries\SPI (legacy)
Using library SdFat_-_Adafruit_Fork at version 1.5.1 in folder: C:\Users\Wayne\Documents\Arduino\libraries\SdFat_-_Adafruit_Fork
Using library Adafruit_ImageReader_Library at version 2.8.1 in folder: C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_ImageReader_Library
Using library Adafruit_GFX_Library at version 1.11.3 in folder: C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_BusIO at version 1.13.2 in folder: C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire in folder: C:\Users\Wayne\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\3.2.0\libraries\Wire (legacy)
Using library Adafruit_EPD at version 4.5.0 in folder: C:\Users\Wayne\Documents\Arduino\libraries\Adafruit_EPD
exit status 1
wfitkin
Post by wfitkin »
Bottom line for me is that any sketch with #include <Adafruit_SPIFlash.h> and/or <Adafruit_ImageReader.h> will not compile if your board is a Raspberry PI Pico.
wfitkin
Post by wfitkin »
Tried the example "Adafruit Image Reader Library/ ShieldILI9341" one another computer using a Raspberry Pi Pico as the board with the same result.
Easy to duplicate..
Just open a new sketch using a Raspberry Pi Pico and add the following two lines at the top then hit compile.
wfitkin
Post by wfitkin »
mikeysklar
Have you installed the "Earle Philhower core" board manager library which the SPIFlash supports? The instructions are here:
https://learn.adafruit.com/rp2040-ardui ... hower-core
Add this to your Arduino IDE Preferences --> Additional Boards Manager Library URLs:
https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
Tools -> Board -> Board Manager and type pico into the search bar, and hit enter. Select Raspberry Pi Pico/RP2040 by Earle F. Philhower, III and press Install.
wfitkin
Post by wfitkin »
Mikeysklar,
You are amazing!!!
That did the job 100%
Thank you so much!
mikeysklar
Glad to the Earle Philhower core resolved it. Thank you for the confirmation.
IAmOrion
Post by IAmOrion »
I've just come here with the exact same problem:
I know the previous response mentions Earle Philhower's core -- but oftentimes, switching cores just isn't feasible! As in my particular case. Switching to Earle Philhower's core gives me what feels like a bajillion different errors for other stuff in my code, that his core just doesn't support, but the official rp2040 does. Not to mention not wanting to rewrite 2000+ lines of code to re-work with different libraries under a different core etc.
Sooooooo, does anyone from Adafruit actually have a solution or know why this doesn't work?
Edit: Actually, this doesn't even work on Earle Philhower's core for me! I get the following error:
Adafruit_ImageReader.h:107:3: error: 'File' does not name a type; did you mean 'SdFile'?
  107 |   File file;              ///< Current Open file
      |   SdFile
mikeysklar
On the Earle Philhower's core with your code tried does changing the type help?
File --> File32
IAmOrion
Post by IAmOrion »
mikeysklar wrote: Mon Oct 24, 2022 5:51 pm On the Earle Philhower's core with your code tried does changing the type help?
File --> File32
Yup, that fixes the Examples.... but as mentioned, Earle Philhower's core doesn't work with so much of my current code, re-writing isn't feasible (and some libraries don't work with his core) so need to figure out how to get it to work on the 'official' core
Return to “Other Arduino products from Adafruit”
