Dear Sirs,
I have two sketches to generate sine waves (included bellow).
The first one writes directly to the DAC, the other one uses I2S and the internal converter of the ESP32.
With Arduino IDE and the ESP32 Feather board and the ESP32 board-Manager version 2.0.0
Both sketches work perfectly.
If I update the ESP32 board-Manager to version 2.0.4, I can now work with the Adafruit ESP32 Feather V2.
The Sketch that writes directly to the DAC 2 works perfectly on both the Adafruit ESP32 Feather and the Adafruit ESP32 Feather V2.
But the sketch with I2S, compiles without problems but does NOT work on either the Adafruit ESP32 Feather or Adafruit ESP32 Feather V2. Pin 26 remains at 0v without generating the expected signal.
Evidently the problem is in the Arduino IDE, but there may be a work-around, you could share
On the other hand, I'm sure they have access to the Arduino to escalate the problem.
* Firsy SKETCH Writing directly in the DAC
* Tested on Adafruit ESP32 Feather V2 y Adafruit ESP32 Feather 11-09-2022
#define Num_Samples 112
int i = 0;
// Sin wave
static byte WaveFormTable[Num_Samples] =
0x80, 0x83, 0x87, 0x8A, 0x8E, 0x91, 0x95, 0x98, 0x9B, 0x9E, 0xA2, 0xA5, 0xA7, 0xAA, 0xAD, 0xAF,
0xB2, 0xB4, 0xB6, 0xB8, 0xB9, 0xBB, 0xBC, 0xBD, 0xBE, 0xBF, 0xBF, 0xBF, 0xC0, 0xBF, 0xBF, 0xBF,
0xBE, 0xBD, 0xBC, 0xBB, 0xB9, 0xB8, 0xB6, 0xB4, 0xB2, 0xAF, 0xAD, 0xAA, 0xA7, 0xA5, 0xA2, 0x9E,
0x9B, 0x98, 0x95, 0x91, 0x8E, 0x8A, 0x87, 0x83, 0x80, 0x7C, 0x78, 0x75, 0x71, 0x6E, 0x6A, 0x67,
0x64, 0x61, 0x5D, 0x5A, 0x58, 0x55, 0x52, 0x50, 0x4D, 0x4B, 0x49, 0x47, 0x46, 0x44, 0x43, 0x42,
0x41, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x41, 0x42, 0x43, 0x44, 0x46, 0x47, 0x49, 0x4B,
0x4D, 0x50, 0x52, 0x55, 0x58, 0x5A, 0x5D, 0x61, 0x64, 0x67, 0x6A, 0x6E, 0x71, 0x75, 0x78, 0x7C
void setup()
void loop()
byte wave_type = 0; // Sine
dacWrite(26, WaveFormTable); //25 ou 26
i++;
if (i >= Num_Samples)
i = 0;
* Second SKETCH
* This is an example to write DAC at high frequency using the I2S peripheral
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "soc/rtc_io_reg.h"
#include "soc/rtc_cntl_reg.h"
#include "soc/sens_reg.h"
#include "soc/rtc.h"
#include <Arduino.h>
#include <driver/i2s.h>
#include <driver/dac.h> // libreria necesaria para definir DAC_CHANNEL_1 no es necesaria para DMA DAC
#include "freertos/queue.h"
#define I2S_SAMPLE_RATE 426595
#define Num_Samples 256
int i = 0;
// Sin wave con 256 samples.
0x80, 0x83, 0x86, 0x89, 0x8C, 0x8F, 0x92, 0x95, 0x98, 0x9B, 0x9E, 0xA1, 0xA4, 0xA7, 0xAA, 0xAD, 0xB0, 0xB3, 0xB6, 0xB9,
0xBB, 0xBE, 0xC1, 0xC3, 0xC6, 0xC9, 0xCB, 0xCE, 0xD0, 0xD2, 0xD5, 0xD7, 0xD9, 0xDB, 0xDE, 0xE0, 0xE2, 0xE4, 0xE6, 0xE7,
0xE9, 0xEB, 0xEC, 0xEE, 0xF0, 0xF1, 0xF2, 0xF4, 0xF5, 0xF6, 0xF7, 0xF8, 0xF9, 0xFA, 0xFB, 0xFB, 0xFC, 0xFD, 0xFD, 0xFE,
0xFE, 0xFE, 0xFE, 0xFE, 0xFF, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFD, 0xFD, 0xFC, 0xFB, 0xFB, 0xFA, 0xF9, 0xF8, 0xF7, 0xF6,
0xF5, 0xF4, 0xF2, 0xF1, 0xF0, 0xEE, 0xEC, 0xEB, 0xE9, 0xE7, 0xE6, 0xE4, 0xE2, 0xE0, 0xDE, 0xDB, 0xD9, 0xD7, 0xD5, 0xD2,
0xD0, 0xCE, 0xCB, 0xC9, 0xC6, 0xC3, 0xC1, 0xBE, 0xBB, 0xB9, 0xB6, 0xB3, 0xB0, 0xAD, 0xAA, 0xA7, 0xA4, 0xA1, 0x9E, 0x9B,
0x98, 0x95, 0x92, 0x8F, 0x8C, 0x89, 0x86, 0x83, 0x80, 0x7C, 0x79, 0x76, 0x73, 0x70, 0x6D, 0x6A, 0x67, 0x64, 0x61, 0x5E, 0x5B,
0x58, 0x55, 0x52, 0x4F, 0x4C, 0x49, 0x46, 0x44, 0x41, 0x3E, 0x3C, 0x39, 0x36, 0x34, 0x31, 0x2F, 0x2D, 0x2A, 0x28, 0x26, 0x24,
0x21, 0x1F, 0x1D, 0x1B, 0x19, 0x18, 0x16, 0x14, 0x13, 0x11, 0xF, 0xE, 0xD, 0xB, 0xA, 0x9, 0x8, 0x7, 0x6, 0x5, 0x4, 0x4, 0x3,
0x2, 0x2, 0x1, 0x1, 0x1, 0x1, 0x1, 0x1, 0x1, 0x1, 0x1, 0x1, 0x1, 0x2, 0x2, 0x3, 0x4, 0x4, 0x5, 0x6, 0x7, 0x8, 0x9, 0xA, 0xB,
0xD, 0xE, 0xF, 0x11, 0x13, 0x14, 0x16, 0x18, 0x19, 0x1B, 0x1D, 0x1F, 0x21, 0x24, 0x26, 0x28, 0x2A, 0x2D, 0x2F, 0x31, 0x34,
0x36, 0x39, 0x3C, 0x3E, 0x41, 0x44, 0x46, 0x49, 0x4C, 0x4F, 0x52, 0x55, 0x58, 0x5B, 0x5E, 0x61, 0x64, 0x67, 0x6A, 0x6D,
0x70, 0x73, 0x76, 0x79, 0x7C
void i2sInit()
i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN),
.sample_rate = I2S_SAMPLE_RATE, // The format of the signal using ADC_BUILT_IN
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // is fixed at 12bit, stereo, MSB
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT, // I2S_CHANNEL_FMT_ONLY_LEFT I2S_CHANNEL_FMT_RIGHT_LEFT ****************************************
.communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_STAND_I2S | 0x01),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 8,
.dma_buf_len = 64,
.use_apll = false,
.tx_desc_auto_clear = false,
.fixed_mclk = 0
i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL); //install and start i2s driver
i2s_set_pin(I2S_NUM_0,NULL); // for internal DAC
i2s_set_dac_mode(I2S_DAC_CHANNEL_DISABLE); // disable ambos canales este si funciona
//i2s_set_dac_mode(I2S_DAC_CHANNEL_RIGHT_EN); // DAC_1 RIGHT es el DAC_1
i2s_set_dac_mode(I2S_DAC_CHANNEL_LEFT_EN); // de esta forma tengo solo salida en el DAC_2
// Initialize the I2S peripheral
i2sInit();
// i2s bytes-written variable
size_t bytesOut;
// output the buffer
while( true )
i2s_write( I2S_NUM_0, WaveFormTable, Num_Samples, &bytesOut, portMAX_DELAY );
ESP32 Feather V2 & Ide Arduino & I2S
- mikeysklar
Re: ESP32 Feather V2 & Ide Arduino & I2S
It looks like others have opened issues regarding the ESP32 Arduino Board Manager v2.0.4 and i2s. You can tag your code examples onto one of those or open a fresh issue it seems different in behavior.
https://github.com/espressif/arduino-es ... 3Aopen+i2s
- Enrique_Aguado
Hello
I enjoy working with the Adafruit feather ESP32, but I am having a lot of issues when trying to evaluate the Adafruit feather ESP32 V2.
I have reported de issue with Arduino IDE and I2S
Now I have discovered a new bug with the I2C. In this case working with Visual Studio plus PlatformIO and Adafruit feather ESP32 V2
Same program (with the I2C pins adapted) runs perfect with the Adafruit feather ESP32 board.
I have no doubt about HW Adafruit feather ESP32 V2 but the SW tools are not madure from my experience.
Do you know about any activity running to evalate SW tools.
How long will be the Adafruit ESP32 feather still in production?
When is planned to be substitute the Adafruit ESP32 featherby the Adafruit feather ESP32 V2?
Thanks in advance for your comments
- Enrique_Aguado
Related the problem I have describe ESP32 FEATHER V2 & IDE ARDUINO & I2S
I have found an open escalation opened on 28 Nov 2021
The esp32 i2s internal DAC output is not working with the release 2.0.1
https://github.com/espressif/arduino-esp32/issues/5938
What's has made me to be high worried!!!
Conclusion:
espressif SW tools needed for ESP32 FEATHER V2 project development are not madure
As aI have found bugs in Arduino and PlatformIO
Any action plan from Adafruit to push solving this situation ?
Thanks in advance for any comment.
Conclusion:
