QT PY ESP32 S2 & seesaw not detecting soil moisture sensor 4026
For Adafruit customers who seek help with microcontrollers
OdorDecoder
Post by OdorDecoder »
When I use the QT PY ESP32 S2 board and connect it through a GROVE to STEMMA/QT 4-wire connector, and try the soil_sensor example as found on https://learn.adafruit.com/adafruit-ste ... duino-test the sensor is not found. The I2C scan test, as found on https://learn.adafruit.com/adafruit-qt- ... -scan-test for the QT PY2 ESP32 works just fine, finding the soil moisture meter at 0x36. I have 2 of these QT boards and 2 of these soil moisture meters, the results are the same when mixed and matched. I am aware of the "Wire1.setPins(SDA1, SCL1)" required line in setup, and I did get this to work in circuitpython. Here is my code:
#include "Adafruit_seesaw.h"
Adafruit_seesaw ss;
  Serial.begin(115200);
  Wire1.setPins(SDA1, SCL1);
    // wait for serial monitor to open
  while(! Serial);
  Serial.println("seesaw Soil Sensor example!");
  while (!ss.begin(0x36))
    Serial.println("ERROR! seesaw not found");
  Serial.print("seesaw started! version: ");
  Serial.println(ss.getVersion(), HEX);
  float tempC = ss.getTemp();
  uint16_t capread = ss.touchRead(0);
  Serial.print("Temperature: "); Serial.print(tempC); Serial.println("*C");
  Serial.print("Capacitive: "); Serial.println(capread);
  delay(100);
adafruit_support_mike
Re: QT PY ESP32 S2 & seesaw not detecting soil moisture sensor 4026
OdorDecoder
Here is a picture of my setup. I power it via USB-C (duh).
I'm not sure the cable is fully seated in the sensor's connector. Make sure that connection is good and see if it has any effect.
OdorDecoder
It's fully seated, of course! I got it to work in CircuitPython like I said, It's a BANNED plug that you have to shave down. Have you tried this configuration? It doesn't work. I have 2 of each, AND I got it to work with other software. What more proof do you need?
OdorDecoder
HA! the word cr*p comes out as "banned" oh my lordy, goodness mercy!
Return to “Microcontrollers”
