Hello friends, I have a question to see if you can help me. I have a raspberry pi400 with the cyberdeck adapter installed in its gpio port and I have obtained an adaf_3651 screen (adafruit tft featherwing 3.5" 480x320 touch). The problem is that I don't know If this screen model can be installed on the cyberdeck or is some other type of adapter necessary?
As you can see in the photos, the pins do not fit well due to connection layout issues, which makes me think that this screen model is not suitable for this adapter. is that so? If not, is there another way to make it work? Is it possible to expand the connection of the screen or the adapter to make it taller?
Thank you very much in advance
install tft feadtherwing in cyberdeck (raspberry pi400)
- mscamps
- ada-min.png (569.05 KiB) Viewed 74 times
- mikeysklar
Re: install tft feadtherwing in cyberdeck (raspberry pi400)
The screen you bought is specific to the Feather controllers. It is not designed to work with Raspberry Pi GPIOs or Cyberdeck Hat / Bonnet.
You will want to get a screen that is compatible with the Cyberdeck.
If you have a Cyberdeck HAT there are a list of display on this page that are compatible with it:
https://www.adafruit.com/product/4863
Here are some of our favorite displays we recommend:
Adafruit PiTFT 2.2" HAT Mini Kit - 320x240 2.2" TFT - No Touch
Adafruit PiTFT 2.4" HAT Mini Kit - 320x240 TFT Touchscreen
PiTFT Plus Assembled 320x240 2.8" TFT + Resistive Touchscreen
PiTFT 2.8" TFT 320x240 + Capacitive Touchscreen for Raspberry Pi
Adafruit PiTFT Plus 320x240 2.8" TFT + Capacitive Touchscreen
Adafruit PiTFT - 320x240 2.8" TFT+Touchscreen for Raspberry Pi
PiTFT Plus 320x240 3.2" TFT + Resistive Touchscreen
PiTFT - Assembled 480x320 3.5" TFT+Touchscreen for Raspberry Pi
PiTFT Plus 480x320 3.5" TFT+Touchscreen for Raspberry Pi
If you are cool with cutting a trace on the HAT, you can also use:
Pimoroni HyperPixel - 4.0" Hi-Res Display for Raspberry Pi
Pimoroni HyperPixel - 4.0" Hi-Res Display for Raspberry Pi - Non-Touch
